Engine brake in winter
Discussion in 'Experienced Truckers' Advice' started by lostinblue, Dec 19, 2012.
  1. lostinblue
    lostinblue Bobtail Member
    15
    4
    Feb 16, 2010
    rochester ny
    I am driving a peterbilt straight truck 26 ft box. It has automatic and an engine brake.Twice a day I drive a mile long hill. Don't know how steep but I stab around 5-6 times and have 35 mph at the top and 45 mph at the bottom. Owner thinks an engine brake would "throw" you. Another trucker said don't ever stop going up you will never get started again in winter. Going down this hill in the winter if a bit icy engine brake or not. A lot of local drivers seem scared of this hill. Looking for good advice. We have no chains on any trucks. Tires are in good shape. Perhaps drop it into first or second instead of drive.?Engine brake will keep me at 35 mph on dry pavement downhill.Like I said owner also drives this hill at times and is less than impressed with engine brakes.
  3. 900,000-tons-of-steel
    900,000-tons-of-steel Road Train Member
    1,511
    896
    Aug 17, 2012
    Florida
    EVERY CDL manual says no retarder when on icy roads.
    jimvrg, a proud yankee and Calspring Thank this.
  4. jonboy29
    jonboy29 Light Load Member
    297
    187
    Jul 9, 2010
    Home Sweet Home... SW Ont.
    doesn't that manual tell you to not speed and obey all laws?
    now I know why I didn't read that book!!!
  5. p38fln
    p38fln Bobtail Member
    Superior, WI
    The reason you don't use an engine brake on an icy hill is you are only braking the rear axle at this point. By only braking the rear axle, you could cause the rear axle to break traction, which could easily spin you sideways. That's not to say it's always going to happen, and is definitely a worst case scenario. The best option on an icy downhill grade is to start slow and in a very low gear and forget about the engine brake. If you're accelerating to 45 MPH when you try to use the brakes alone, use a lower gear and start at a slower speed at the top of the hill.
  6. VisionLogistics
    VisionLogistics Road Train Member
    1,551
    978
    Dec 8, 2011
    Jellystone
    I use the lowest stage on mine and it never breaks loose. On the highest stage it has broken loose though, and got sideways. Why don't you have chains? If you were chained up you'd be able to run the middle or high stage and not have a problem either.
    jonboy29 Thanks this.
  7. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,909
    54,885
    Dec 8, 2012
    hunting...../ retired
    Use of an engine brake on icy or even wet roads is a recipe for a jack-knife situation....let it be and don't attempt to use it!
  8. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    I'd worry more about jacknifing from cruise control on icy/wet roads.
  9. LandShark
    LandShark Road Train Member
    1,525
    1,064
    Nov 22, 2008
    Riverdale, Ga
    Really. Well guess you better run up north and tell them ice road truckers to stop using the jake cuz they say hitting the brakes causes slides and the jake is the best way to slow down
    bbechtel16 Thanks this.
  10. lucky07
    lucky07 Light Load Member
    197
    118
    Jan 15, 2012
    Ottawa, ON
    Winter and #### conditions means no cruise control and retarder on the lowest setting ( turn it off completely if you don't have a 3 stage). Every truck I've driven has been fine running the retarder on the lowest setting in the winter. This doesn't mean it'll work for you though, try it when it's safe to do so and see how the truck reacts. Use it on the highest setting and there's a good chance it'll put you sideways right quick... I wouldn't try it just for ##### and giggles.
    Using the engine brake on the lowest setting, which basically does nothing but help a tiny tiny tiny tiny little bit is no more dangerous than not using it at all and stabbing at the brake in slick conditions. Every time you touch that brake pedal you risk puttin' her sideways. 99.9 percent of the time nothing happens but believe me when I tell you that you do not want to be in that .01 percent :) .
    Cruise control ... well, if you hit black ice and your truck slows down, it'll give her fuel "without user input" to get it back up to speed and can make for one hell of a ride. If your one of those guys that kills the cruise with the brake pedal, I'd get used to using the clutch to do that. Killin' the cruise with the brake in an emergency situation can make things much worst very fast.
    And about the don't ever stop going up thing. Hammer down and keep her there, don't break loose and you'll be fine. If a four wheeler stops in front of you just push 'em up the hill lol
    bbechtel16 and spacester Thank this.
  11. lucky07
    197
    118
    Jan 15, 2012
    Ottawa, ON
    Who told you that?
