Engine brake partly works
Discussion in 'Freightliner Forum' started by 6t7gto, Nov 16, 2011.
  1. 6t7gto
    6t7gto Bobtail Member
    5
    bedord,ohio
    94 freightliner S60 detroit.
    This truck has 2 switches to control the engine brake.
    1 switch for 2 cylinders another for 4 cylinders.
    2 cylinder switch works fine. 4 not all.
    I replaced the switch and the 4 side still does not work.
    Any ideas of where to start looking?
    I assume the 2 side actuates two cylinders...say 3 &4.
    and the 4 side would actuate the remaining 4 cylinders. correct?
    would it be possible for all 4 solenoids to fail?
    thanks,
    david
  3. KW Parts Guy
    KW Parts Guy Light Load Member
    230
    78
    Jul 16, 2011
    Probably not but there maybe a problem within the jake wiring harness!
  4. 6t7gto
    5
    bedord,ohio
    thanks for the reply.
    david
  5. dave26027
    dave26027 Road Train Member
    1,284
    799
    Sep 10, 2009
    Dallas, Texas
    It's usually the harness, there's a connector on the side of your engine that everyone has trouble with, the pins in it are frail. A quick diagnostic at a shop should show you where the problem is.
    If you have a LOT of miles on the engine and the compression brakes are rarely used it might be a mechanical problem, could also be time to PM the compression brake, it's usually done as part of an overhead adjustment.
  6. Sparkz
    Sparkz Light Load Member
    76
    15
    Jul 10, 2011
    New Zealand
    David, I assume this is a DDECIII engine.
    There are three solenoids that each operate the Jakes on two cylinders.
    Low is 3 & 4. Orange wire 562 from ECM terminal T3.
    Medium is 1 & 2 and 5 & 6. Red wire 561 from ECM terminal S3.
    High is all six cylinders.
    The ECM monitors the resistance of the solenoids and will log a code 31 if the resistances are outside specs.
    To request Jakes the dash switches ground out two input wires, usually wires 583 from K2 and 979 from K3. My guess would be that you have a break in one of these two wires somewhere between the ECM and the switches.
    With the key on and switches off, you should have voltage on both wires(5v?).
    Turn the switch on and the voltage will drop to 0.
  7. 6t7gto
    5
    bedord,ohio
    Thanks for the replies.
    I'll check it out and report back.
    David
  8. 6t7gto
    5
    bedord,ohio
    sparkz,
    I put my voltmeter on the 2 terminals on the back of the switch and read 4.5 volts with the key on and the switch off.
    turned the switch on and voltage dropped to zero.
    so I assume the harness from the dash to the ECM is intact.
    dave26027,
    the connector that you mentioned is way up on top of the bellhousing.
    just about impossible to get at.
    this is a FLD with the rear of the motor tucked into the cab some.
    not much room to get to the rear of the head.
    any other thoughts?
    thanks,
    david
  9. Sparkz
    76
    15
    Jul 10, 2011
    New Zealand
    Is this correct?
    With both switches off there are wires on the back of both with 4.5v.
    The wire on the back of the 2cyl switch drops to zero when the switch is turned on, but the wire on the 4cyl switch stays at 4.5v.
    The wire on the back of the 4cyl switch drops to zero when the switch is turned on, but the wire on the 2cyl switch stays at 4.5v.
    This would lead me to believe that the wiring is ok. You would need to connect a reader or laptop to confirm this.
    The 2-pin connector for the Jake solenoids is just below the inlet manifold, above the starter. Usually about 6" from the rear of the block.
    I doubt that this is your problem, as the ECM will log a code 31 if it detects high or low resistance in the solenoid circuits.
    Don't you just love those trucks with the engine half in the cab. Short bonneted Western Star's are about the worst.
  10. 6t7gto
    5
    bedord,ohio
    Sparkz,
    Thank you for your time.
    I didn't check the voltage on the 2 cylinder switch, just the 4 cylinder switch.
    As this is the one malfunctioning.
    I'll check it out Friday and report back.
    Have a nice day.
    David
  • Draft saved Draft deleted
