Engine brake won't turn off.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SlugLife, Apr 30, 2014.
  1. justa_driver
    justa_driver Road Train Member
    1,105
    817
    Apr 2, 2014
    Tennessee
    Hmmm most have an engine brake fuse. If nothing else, just pull the panel off that your switch is in and unplug the switch. Its probably bad. they wear out. Might even have the fuse connected to the plug in the dash?
  3. BeenJammin
    BeenJammin Light Load Member
    256
    118
    Dec 17, 2013
    Sounds like you got too many switches for the same function if I'm understanding you corectly. You're saying you have a single toggle marked high-off-low and you have it in the up position? Is that up position high or low? Have you tried it in the center-off postion. Sounds like somebody has installed an extra switch for some reason. I can't see why you would have three switches, one on-off and one hi-med-low and another low-off-hi. Sounds like an industrious mech doing a quick fix for a part problem or something another. One of them if somebody worked on it first problems. Is it still unlatching the jakes at below 800 to 900 rpm? If not, you definitely got a chonudrum. You're bypassing all ecm functions and going back to the manual set up days.
  4. justa_driver
    1,105
    817
    Apr 2, 2014
    Tennessee
    no he said there were two retarder systems available for that truck. said he had the single switch system. Hey slug go back to your fuse panel diagram and see if theres a relay in there that says engine retarder? yea he said he had it in the center(off) position but it wasn't cutting it off. The switch is probably bad. Was trying to locate the engine retarder relay location on the internet but never found it. According to one site I was on it said the truck had all relays instead of fuses and said it had an engine retarder relay but it didn't say where it was located.
  5. BeenJammin
    256
    118
    Dec 17, 2013
    My bad, I thought he was talking about what he was seeing on his dash, not what he was researching, sorry.
  6. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    pull the wire that goes to the clutch switch. then it will never come on
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Does the switch actually say high/off/low? I'm curious because we have several with a single switch on the dash that is high/med/low and the 2nd switch is on the shifter for on/off. It has confused many drivers that were not used to it at first.
  8. justa_driver
    1,105
    817
    Apr 2, 2014
    Tennessee
    No Problem. I misread it myself the first time.
  9. justa_driver
    1,105
    817
    Apr 2, 2014
    Tennessee
    Yea he said he has the single switch system. High on top, off in the middle and low on the bottom.
  10. Cetane+
    1,304
    882
    Sep 29, 2013
    Albany, NY
    can you give me a part number to that shifter switch
    I wanna see about putting one on the shifter for my 18 speed
  11. EverywhereMan
    EverywhereMan Medium Load Member
    304
    392
    May 28, 2013
    The North
    Just mash through the gears at the truck stop and let the jake work it's magic. Everyone will know you mean business and you're a real bad boy.
