Engine brake
Discussion in 'Questions From New Drivers' started by Littleguy101, Dec 14, 2016.
  1. Littleguy101
    Littleguy101 Bobtail Member
    Engine brake on snowy water roads is it okay? I heard you can if it's on the lowest setting just wondering what you guys think thanks
  3. TripleSix
    133,734
    Depends on you the driver. Something like that shouldn't have hard fast rules.
    magoo68, Longarm, j_martell and 3 others Thank this.
  4. AModelCat
    165,146
    Exactly. Some of the roads my dad used to haul off of in winter if you didn't use the jake you'd be 3 days trying to crawl down in low. Of course chains and lockers help prevent wheel lockup.
  5. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    If you can apply full power/torque and not break traction, you're probably safe to utilize engine brakes. But I think in most icy situations, even with decent traction, stepping down to mid or low is prudent. However, there are many situations when using engine brakes should be avoided altogether. Experience and situational awareness is your best guide.
    But you should use your service brakes when you can to work to keep them "dry" when on largely slushy roads. You may find you have poor initial braking capacity after running in slush a long time and first use your brakes to slow significantly or stop.
    j_martell, Lepton1 and DDlighttruck Thank this.
  6. Lucy in the Sky
    Lucy in the Sky Medium Load Member
    560
    766
    Dec 19, 2015
    Jake brake + Johnny bar is pretty good on slick roads
    Lepton1 Thanks this.
  7. okiedokie
    okiedokie Road Train Member
    14,072
    112,092
    Jun 13, 2011
    PNWET
    Actually throttle & service brakes is my prefered method. But this is for off road steeper grades. Jakes can be useful but use with caution on lower settings.
  8. okiedokie
    14,072
    112,092
    Jun 13, 2011
    PNWET
    This is bad information. Jacknife just ahead.
    Toomanybikes Thanks this.
  9. rzl-dzl
    rzl-dzl Medium Load Member
    477
    175
    Dec 16, 2011
    100 mile house
    snow is irrelevant.
    slippery is what matters....
    basically what he said.
    if i can go down the hill empty with my jakes on, i can get back up it loaded without chains.
    in slippery conditions i turn the jakes low, sometimes off.
  10. Lucy in the Sky
    560
    766
    Dec 19, 2015
    How so? Using the jakes by themselves you will jacknife
  11. Toomanybikes
    Toomanybikes Road Train Member
    2,499
    3,524
    Apr 8, 2009
    ^^ Last place you want to put any braking on in the slick is the drive axles right in the middle of your truck.
    A driver should be able to drive with a jake.
