Engine brakes and windshield wipers
Discussion in 'Questions From New Drivers' started by Russian, Dec 17, 2016.
  1. Russian
    Russian Bobtail Member
    47
    78
    Dec 12, 2016
    brighton beach, ny
    Been driving 9 years accident free.
    And I don't understand why safety guys at most companies I worked say this:
    "Don't use engine brake on wet roads or in the snow".
    I just ignored them and especially use those jake brakes in winter conditions - helps me to slow down gradually, nice and easy.
    So my truck went to shop on wednesday and I got one of those newer kenworth trucks as a loaner until sunday.
    Had to drive it thru western PA last night - quess what? If you turn the wipers on the jakes won't work !
    I am the only one using engine brakes in winter?
    Do you guys use it in bad weather??
  3. mitrucker
    mitrucker Road Train Member
    5,500
    10,395
    Dec 15, 2010
    Lapeer, MI
    Absolutely not!!!!
    LGarrison and Russian Thank this.
  4. Quackers
    Quackers Light Load Member
    104
    111
    Nov 17, 2016
    Ky
    Well if OP is actually from Russia our winter weather probably isn't much of a comparison lol
    Russian Thanks this.
  5. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Absolutely I do. Some conditions I don't but to think that any time you need the wipers you shouldn't use the brakes is desk driver absurdity.
    alpo718, MACK E-6 and Russian Thank this.
  6. Zeviander
    Zeviander Road Train Member
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    I can't even imagine the frustration that must cause, getting into a piece of equipment that won't let you use it how you want to.
    thejackal, alpo718, magoo68 and 6 others Thank this.
  7. Ridgeline
    22,757
    124,212
    IT is equal to having the rear breaks lock up on wet or on icy roads, you slide.
    I know, I've done it on a skid pad.
    wis bang and WiggleWagon Thank this.
  8. KillingTime
    KillingTime Road Train Member
    3,865
    61,879
    Mar 26, 2016
    Rockland, Maine
    You never tried to play an original 8-bit Nintendo, did you?
    This machine is the root of my youthful disappointment with things, particularly machines. Lol.
    Bo Hunt Thanks this.
  9. WiggleWagon
    WiggleWagon Light Load Member
    232
    312
    Aug 17, 2016
    Parked At The Fuel Island
    I have used engine brakes loaded (heavy) only, and very carefully when it is raining, never in the snow, I never do if I am empty or light. Ridgeline is exactly the reason I was told to do it this way. It can break the traction of your rear wheels and cause a jackknife accident. No trailer equals e-brake on a dirt road. It's that tiny little bump that starts at the engine brake, slowing the engine, forcing everything behind it to slow down. That little bump having traveled back to the rear end and wheels, is what will cause traction to break. The wheels don't even need to lock up. If it's slick enough, just that little bit of rolling hesitation will send you in to a slide.
    I think that wiper disabling engine brake is just silly. There must be some setting in that trucks computer that can change that. With everything else they can make these trucks do no reason to believe otherwise.
  10. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    One day. One day the OP will discover there are some slick conditions that the "reverse torque" from the engine brakes is sufficient to lock up the drives. And when this happens in a curve I'm going to laugh myself silly.
    But excluding their use with wiper use is dumb but I'm sure this was brought about by a bunch of poorly taught drivers who did not know basic engine brake usage protocol and perhaps had the same misguided understanding as the OP. [Read the owners manual for further clarification]
    Kind of ironic, huh. The one complaining may be part of the reason behind the subject of the complaint.
    Zeviander Thanks this.
  11. Stormy 69
    Stormy 69 Medium Load Member
    455
    780
    Jul 1, 2016
    Confusion
    He's still a rookie. He will learn
