Engine breather
Discussion in 'Volvo Forum' started by JPSIPPY, Mar 16, 2019.
  1. JPSIPPY
    JPSIPPY Bobtail Member
    30
    7
    Dec 13, 2011
    cambridge,on
    I got 15 volvo670 d13.its engine breather keep running for about 30-40 seconds even after engine shutoff. What could be wrong. Tia.
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    probably built up gases?
    a mechanic i knew, used to use some sort of brush (thin) in a wire handle and go up there to clean it out.
    JPSIPPY Thanks this.
  4. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Engine breather....Im thinkin its just the egr cooler winding down..
  5. JPSIPPY
    30
    7
    Dec 13, 2011
    cambridge,on
    Is it ok or not.i m buying this Volvo 1st time.
  6. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Its a normal thing but i didnt hear it to say for sure...
    I shure as hell hope you did a TON of inspecting before you considering it..
    Back ground chks,fuel records,dealer records,oil samples,ecu download....Research the #### outta it before you fork over the $...
    Gambosa and JPSIPPY Thank this.
  7. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Not sure what you're calling an engine breather, you might be hearing the DEF pump emptying the line or there's always a clicking sound that comes from DPF side as well, that's all normal.
    magoo68 and AModelCat Thank this.
  8. kemosabi49
    10,977
    47,916
    Jan 13, 2013
    SW Arkansas
    And a dyno run with blowby test
  9. JPSIPPY
    30
    7
    Dec 13, 2011
    cambridge,on
    Noise is coming from driver side engine .it like air leak or like turbo spinning
  10. Mudman78
    Mudman78 Light Load Member
    106
    108
    May 23, 2016
    It's the crankcase breather spinner. It condenses the fumes and sends the oil back to the pan, rather than out into the atmosphere for emissions purposes. It's normal.
    Gambosa, KB3MMX and JPSIPPY Thank this.
  11. d281833
    881
    919
    May 15, 2012
    Well there's no turbo driver side, DEF pump is a whirring sound driver side. Check the compressor line driver side, towards rear of engine. Not sure what more we can tell you here, other than take it into a shop. Hard to diagnose on a forum.
