engine ecu code (fuel drive stage) electrical
Discussion in 'Volvo Forum' started by pizaboy, Oct 27, 2011.
  1. pizaboy
    pizaboy Bobtail Member
    Dalmatia, Pa.
    I bought a 2005 volvo truck a month ago. A couple of days after I bought it I got a check engine ecu code ("fuel drive stage electrical").
    Then while driving it, loaded pretty heavy going up a steep grade I lost all power had to crawl up to the crest of the grade.
    took it to volvo they said it need O rings on the injectors...Called the dealer where I bought it he told me to take it to the garage he deals with. They put the O rings on. When I went to pick it up it ran worse then when I took it there. So then they said it needed a fuel pump so they put one on. Then they said it had a cracked injector...put one of those in. Still getting same error message, truck still has issues going up hills loaded. Wondering if anyone has had similar problems..any feed back would be greatly appreciated
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    what engine? D12 ore D13B?
    KB3MMX Thanks this.
  4. pizaboy
    Dalmatia, Pa.
    D12 Took it to volvo yesterday replaced lift pump, while there an injector went bad...replaced that,changed both the fuel filters...drove it home still getting the same error codes:biggrin_25521:
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    can you post me full code like MID 128 SID-PID FMI?
    KB3MMX Thanks this.
  6. DINO MOSTAR
    DINO MOSTAR Bobtail Member
    8
    I have the same problem with my truck.I'am wondering if you have fixed your problem? D12 engine 2004.Thank you
  7. DINO MOSTAR
    8
    Hello,I'am new guest on this forum.I need help! I got 2004 Volvo engine D12 automatic transmision 465 hp.I lost power,so my truck does not have too much power,especially the heavy loads.The codes that I got are Mid 128,Sid 211,Fmi 4.....Mid 128,Sid 78,Fmi 5 and on the dashboard it says"fuel feed pump driver stage electrical problem". For the past four months I have changed turbo,both egr valves,I changed the air cooler,adjusted valves and injectors.I keep up with my truck very well,truck is idoling smoothly.Right now my Mpg is 5.0.My driver says that sometimes while he is driving it pops out of gear for 2 seconds and and then back to gear by itself(in that moment the Rpm goes high) even thou if it is in the 10th gear it feels like it needs a higher gear.I have changed the shifter like 3-4 months ago,my mechanic changed the alternator,new batteries and checked all harnests.These codes I found on the forums and what they mean.If i'am not mistaken it is fuel pressure sensor,I doubt it's because of that.
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    bad wiring, sensor supply 5V is short to ground and all sensoors are not supplied and engine loose power
    KB3MMX Thanks this.
  9. DINO MOSTAR
    8
    So what is my next step.....what is the sensor supply 5V........more details...please.......thank you
  10. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    all sensors are +5V supplied. If one is short ore bad wiring no sensors read data
    KB3MMX Thanks this.
  11. DINO MOSTAR
    8
    The way I see it,Pablo you are a doctor for the trucks.My mechanic checked all the wireing he did not find anything suspisious.How do I know which sensor is bad?Thank you
