I need help with mine when I cut my headlights on the engine fan cuts on when i cut my engine fan on my headlights cut on I'm dumbfounded
Engine fan for 1998 379 pete
Discussion in 'Peterbilt Forum' started by Cindy, Jul 24, 2012.
Page 3 of 3
Hola bu3n día. Me podría ayudar donde sea en cuenta el relé del ventilador del motor.
Yes I got similar problem as this guy I got 2000 peterbilt 379 but with 1999 cat motor my fan will cut on with switch but not with a/c and will not cut on with temp rising do u have any ideas and do u know if 2000 model has fuse and relay behind speedometer panel
I’m having the same problem with my 98 pete 3406E. Last time it was on the road everything worked fine including the engine fan/switch. Now that I’ve put it back together and running again the fan doesn’t turn on. The light comes on the dash when the switch is flipped but it’s not actually working. Changed the solenoid on the firewall and still nothing. Any suggestions please?
Danny didyoufigureoutyourproblem?
I have one that won't come on with temperature or ac pressure.
it works only when turning on manually -
Page 3 of 3
