Engine Fan Kick off stopped/Engine runs hot when ideling
Discussion in 'Volvo Forum' started by pareshsaini, Nov 1, 2019.
  1. pareshsaini
    pareshsaini Bobtail Member
    7
    Hello,
    I have Volvo 2007 with ISX Cummins. Engine has 830k miles.
    1) Engine gets hot around 200 when Ideling
    2) A/c has stopped working.
    Morning when I started my truck, I heard minor metal crackel sound around radiator/Fan area but that sound stopped after few minutes. I asked my mechanic over the phone and he told me Fan Clutch could be problem but when he checked fan clutch he said fan clutch is fine.
    I changed my radiator few months back.
    Any suggestions are appreciated
  3. Concorde
    Concorde Road Train Member
    5,482
    19,461
    Jun 29, 2016
    West Melbourne Florida
    Fwiw..simple way to check your fan clutch is to try and turn the fan with your hand..engine off of course :)
    If it turns freely it is bad.. if it’s tight then it’s good.
    Not sure what you mean by “engine fan kickoff stopped”
  4. pareshsaini
    7
    Thanks for your reply.
    I tried the way you explained how to check if fan clutch is bad. It is not free. So fan clutch seems good.
    When engine over heats and fan starts to cool down engine that is what i would say Engine fan kick-off. Well I just noticed it starts at 210. So my problem is only Over heating when ideling and a/c not working. Any guess on that?
  5. Newto Trucking
    Newto Trucking Medium Load Member
    359
    226
    Dec 26, 2013
    NE Illinois
    If you low on Freon it might do that. Check and recharge it if needed
  6. Ridgeline
    22,724
    123,361
    Unless you are in Death Valley, if your truck is hitting 200 just idling, it needs to be looked at because it isn't the a/c.
    KB3MMX and Snailexpress Thank this.
  7. pareshsaini
    7
    Yes, engine gets around 210 when ideling in cold Michigan weather. A/c can be a separate issue but I noticed both problem at the same time.
  8. speedyk
    speedyk Road Train Member
    1,837
    2,471
    Apr 8, 2015
    Is the fan cycling on and off?
  9. AModelCat
    164,674
    A/C probably doesn't work because your fan isn't pulling heat out of the condensor. Fix your fan first, then worry about the A/C.
  10. pareshsaini
    7
    Yes fan does cycling (fan on/off)
  11. pareshsaini
    7
    Yes, that makes sense. I need to worry about enginge over heating/fan. A/c is secondary. Thanks
