Engine fan on, coolant temp low.
Discussion in 'Ask An Owner Operator' started by BJSingh_TruckersReport, Oct 24, 2021.
  1. BJSingh_TruckersReport
    BJSingh_TruckersReport Bobtail Member
    7
  3. Spyro2112
    Spyro2112 Medium Load Member
    642
    446
    Mar 17, 2018
    Fan clutch, air fitting, thermostat
  4. lester
    2,958
    8,091
    Jan 2, 2012
    NW, Iowa
    Make, model, year or truck? Engine?
    msh Thanks this.
  5. BJSingh_TruckersReport
    7
    2013 Peterbilt 365, Cummins ISX 11.9.
  6. Antinomian
    Antinomian Road Train Member
    2,193
    3,492
    Feb 17, 2013
    Add AC high pressure switch to that list.
    mtoo and msh Thank this.
  7. msh
    msh Light Load Member
    159
    110
    Jul 18, 2021
    Los Angeles, CA
    most likely this switch is malfunctioning.
    mtoo Thanks this.
  8. Gliding ProStar
    Gliding ProStar Heavy Load Member
    860
    6,132
    Nov 12, 2016
    Waxahachie, Texas
    Just to make sure, you don't have the fan switch in the "ON" position on the instrument panel do you?
  9. cke
    cke Road Train Member
    6,274
    77,160
    Aug 4, 2013
    Colfax Wi
    Is the a/c turned on. Is the defrost turned on. That will turn the a/c on in turn turning on the fan.
  10. mtoo
    mtoo Road Train Member
    1,942
    4,526
    Jan 15, 2011
    Retired on bended knee
    X2
  11. mtoo
    1,942
    4,526
    Jan 15, 2011
    X2 sorry double post
