Engine fan on, coolant temp low.
Discussion in 'Ask An Owner Operator' started by BJSingh_TruckersReport, Oct 24, 2021.
  1. mtoo
    mtoo Road Train Member
    1,942
    4,526
    Jan 15, 2011
    Retired on bended knee
    X2
  3. BJSingh_TruckersReport
    BJSingh_TruckersReport Bobtail Member
    7
    I do have a switch on the dash for the fan, it’s in the AUTO position. The fan is on with or without A/C on.
    I see two pressure switches by the EVAP valve, both are labeled A/C HP Switch. I have another pressure switch on the SMALL Line coming out of the A/C Compressor, this one is labeled A/C Pressure Switch…which one controls the fan?
  4. mudflap77
    mudflap77 Heavy Load Member
    864
    1,314
    Oct 11, 2010
    South western Ontario
    Build up air, shut the engine off, turn the key to the on position (make sure the a/c is off and engine temp is low enough that the fan won't be locked), try to spin the fan by hand. If you can't turn it your fan clutch is worn out.
  5. BJSingh_TruckersReport
    7
    Thanks mudflap77
    The fan turns fine!
  6. mudflap77
    864
    1,314
    Oct 11, 2010
    You're welcome. Next step is connect cummins insite and see what is calling for the fan..
  7. BJSingh_TruckersReport
    7
    Man, i was hoping to avoid the expense of a diag charge from Peterbilt.
  8. Gliding ProStar
    Gliding ProStar Heavy Load Member
    860
    6,132
    Nov 12, 2016
    Waxahachie, Texas
    I wouldn't take it to Peterbilt. I would go to a local independent with a proper scan tool or Cummins Insite and ask them to diagnose it.
  9. Long FLD
    Long FLD Road Train Member
    13,019
    54,647
    Mar 4, 2015
    Wasn’t on a Cummins, but I had an intake air temp sensor go bad on a Cat and it caused the fan to run constant.
  10. Antinomian
    Antinomian Road Train Member
    2,193
    3,492
    Feb 17, 2013
    Try unplugging those AC high pressure sensors you found first and see if one of them makes the fan turn off. You may need to stop the engine and unplug it, then start it up. Worth a try, though I don't know if those are normally-closed or normally-open switches. The other thing that will make the fan come on is the coolant temperature sensor.
