engine fan runs constant
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Perchie15, Aug 4, 2023.
  1. Perchie15
    Perchie15 Light Load Member
    247
    75
    Aug 16, 2021
    I did by pass the coolant temp sensor that’s in the reservoir tank well the male side and fan still stayed on, WHERES the other sensor then?
    Rideandrepair Thanks this.
  3. JB7
    JB7 Road Train Member
    1,008
    1,781
    Dec 13, 2022
    Laurel, MD
    The one in the tank should be the coolant level sensor. What year truck? Are there any codes? Did you carefully watch the video?
    Detroit DD13/15/16 I6 Engine Sensor Locations – TroubleCodes.net
  4. Lazer
    Lazer Road Train Member
    1,848
    2,978
    Jan 22, 2017
    I believe that is true on the newer generation of trucks.
  5. Perchie15
    247
    75
    Aug 16, 2021
  6. Perchie15
    247
    75
    Aug 16, 2021
    I did now and yeah it works!! No more constant fan!! Thankfully cuz lastnight we blew a belt on the truck. But still no ac compressor kicking in. Argh
    gekko1323 and Rideandrepair Thank this.
  7. gekko1323
    gekko1323 Road Train Member
    1,659
    2,767
    Jul 14, 2018
    Henderson, NV
    So what was the problem? What exactly did you do to solve the problem?
  8. Perchie15
    247
    75
    Aug 16, 2021
    End up being a broken wire that crosssed under the transmission rubbed through.
    gekko1323 and Heavyd Thank this.
  9. gekko1323
    1,659
    2,767
    Jul 14, 2018
    Henderson, NV
    Thanks for your quick reply. So what exactly did that wire have to do with the fan? My fan has been constantly on since I bought the truck, so I figured now was as good time as any to address it. It's not really doing any harm because the truck runs cool, even in the desert. But the 6.5 mpg and loss of power on hills has compelled me to finally fix it.
  10. Perchie15
    247
    75
    Aug 16, 2021
  11. Perchie15
    247
    75
    Aug 16, 2021
    It ran to the ac compressor and so that means the compressor wasn’t running at all and somehow that was signalling the fan to not shut off that that wire I believe ran to the ECM I never did follow it fully but was headed that direction.
    But there are a few reasons why the fan could be running constantly the hi/low pressure switches. And theirs a triangular switch also. But not all stars have that
    gekko1323 Thanks this.
