Engine Fan will not engage
Discussion in 'Freightliner Forum' started by biofumes, Aug 3, 2012.
  1. biofumes
    biofumes Light Load Member
    202
    96
    Feb 13, 2009
    California
    Complete noob question here, Have a 2000 Fld120 with Detroit 60, and the truck will over heat since the fan will not come on.
    I removed what I think is the frame clutch sensor, and the fan will kick on fine. In other words, the fan works fine, its just not receiving the signal from a certain sensor?
    Any suggestions on what I need to replace?
  3. lonelyswmtrucker
    lonelyswmtrucker Medium Load Member
    612
    248
    Sep 14, 2011
    down the bayou
    change the sensor u disconnected, that could be it
    always start off with the cheapest part first to fix then go up
  4. biofumes
    202
    96
    Feb 13, 2009
    California
    My problem is I don't know the name of that sensor to order it. Its located on the passenger side of the engine, and seems to be bolted on to the engine itself.
    I also, didn't mention that the alarms inside go off, when its disconnected, even though the fan is now turning.
    I guess I can try taking it out and asking for replacement of this here doohickey
  5. snowwy
    snowwy Road Train Member
    20,614
    13,333
    Jul 6, 2009
    every time i've had a fan problem. it's been becuase some doohickey quits working. and it's the same doohickey on every truck.
    i don't know the name. but it's tied into the air system. and i think it's some type of relay.
  6. biofumes
    202
    96
    Feb 13, 2009
    California
    Mechanic hooked the fan up to the thermostat, so it will auto turn on when thermostat is activated. Also, had him install a manual fan switch. He stated the signal came from ecm,cheaper than replacing the ecm.
    Works fine, ready to roll again.
