Engine Harness
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Smellfunny, Nov 23, 2016.
  1. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Does anyone know of a place you can get a harness to switch over engines? I have a customer with a Freightliner Classic with a Cat (6NZ) in it that wants to put a DDEC 5 Detroit in it. The DDEC 5 is in a Freightliner Columbia.
  3. Peterbiltt
    Peterbiltt Light Load Member
    236
    88
    Aug 21, 2014
    Ontario Canada
    Kustom Harness in Oregon or Mawk Industries in AZ. Give em a call and they will tell you everything you need to know and give you the right harness
    Smellfunny, Dave_in_AZ and mp4694330 Thank this.
  4. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    just go to freightliner and get the big harness for a detroit there like 600 bucks
  5. W900AOwner
    W900AOwner Heavy Load Member
    715
    1,288
    Jul 2, 2014
    Sometimes that can open up a family sized can of worms, switching from OEM to another mfgr. ..but those two harness makers will at least stand behind their products.
    Case in point; Recently at a Cummins shop in Charlotte, NC I witnessed a 379 Pete dump truck with a highly noticeable skip. As I kidded with the young tech that was beating it to death around the lot, I asked him if he thought she had a dead hole.
    He said no, the owner just swapped engines from a C13 Cat to a Cummins N-14 Celect Plus, but the wiring harness isn't compatible. Obviously.
