Engine hours vs Engine miles
Discussion in 'Experienced Truckers' Advice' started by Cw5110, Dec 31, 2016.
  1. snowwy
    snowwy Road Train Member
    20,618
    13,340
    Jul 6, 2009
    Imagine trucks that pull tanks. They probably have the most idle time.
  3. AModelCat
    165,508
    Try steam trucks. One place I was at had 3 of them. Over 20k hours and under 50k kilometers on each of them.
    Oxbow and snowwy Thank this.
  4. LOTSO
    LOTSO Heavy Load Member
    894
    2,162
    Mar 28, 2023
    So, which would you choose? 2020 480560/21651 or 2018 558910/15296
  5. kemosabi49
    11,017
    48,119
    Jan 13, 2013
    SW Arkansas
    If you are looking to buy a used truck, getting an ECM dump is one of the thing you need to do. You will see all the particulars about the truck including idle percentage. In addition to getting a dyno with blow by test run, Oil Analysis on all fluids, running a RigDig report and getting a mechanic you can trust go over the truck with a critical eye. Not necessarily in that order and yes, you may spend the money to do that and find the truck isn't worth buying. But better that buying the truck and then find out that is wasn't worth buying.
    Good luck in your search.
  6. LOTSO
    894
    2,162
    Mar 28, 2023
    I've ran 7 RigDig reports, and these are the (2) trucks left. As KR would say, I'm looking for a reason to NOT buy. I thought the high Idle on the 2020 was the reason, but then I thought maybe with it having 78,000 miles less, and having 2-year newer technology, that would offset that.
  7. AModelCat
    165,508
    Miles/hours does nothing for me. The condition of everything else would be what would cause me to choose one over the other.
  8. Gridaxe5588
    Gridaxe5588 Light Load Member
    128
    168
    Nov 23, 2022
    To give you something to let you know both those trucks have idled a ton. My truck which has a generator and hardly ever idles has 789346 miles with only 14625 hours, hope this helps.
    LOTSO Thanks this.
  9. LOTSO
    894
    2,162
    Mar 28, 2023
    Lowest trucks I've seen so far for engine hours are the 2017 Walmart trucks hitting the market now, in the mid 500's have around 11000-11500 hrs. Everything else I've looked at, anything in the 15000 hr. range is low. Most are 18000-20000.
    broke down plumber Thanks this.
  10. jmmtransportllc
    jmmtransportllc Bobtail Member
    4
    Sep 27, 2024
    Sorry about the vague description. 14,600 hours and 436,000 miles on a x15, show that the truck has been idled a lot?
  11. LOTSO
    894
    2,162
    Mar 28, 2023
    I ended up finding a 2020 Cascadia with 419,000 miles and 8025 hrs. Has a TK APU, and Optimized Idle. So very low engine/idle hrs.
    Oxbow and broke down plumber Thank this.
