Engine hours vs Engine miles
Discussion in 'Experienced Truckers' Advice' started by Cw5110, Dec 31, 2016.
  1. Gridaxe5588
    Gridaxe5588 Light Load Member
    128
    168
    Nov 23, 2022
    Yes my 2016 Cascadia has 922300 with hours at 17000
  3. AModelCat
    165,510
    Depends what it was doing.
    broke down plumber Thanks this.
  4. jmmtransportllc
    jmmtransportllc Bobtail Member
    4
    Sep 27, 2024
    The person that is selling it has a fleet of 50 trucks that pull dry van (fedex). From the little I know and the maintenance info he provided, seems like they do a decent job at keep up their trucks.
  5. AModelCat
    165,510
    Ok I'd lean towards lots of idle time.
  6. jmmtransportllc
    4
    Sep 27, 2024
    Thanks. It’s a 2020 T680 in very good cosmetic condition.
  7. Albertaflatbed
    Albertaflatbed Medium Load Member
    420
    1,265
    Nov 20, 2022
    Nisku, AB
    It's idles about 50% of the time based on the miles and hours you noted.
    Still if it is maintained that makes a big difference to any engine.
  8. snowwy
    snowwy Road Train Member
    20,618
    13,340
    Jul 6, 2009
    Was the truck a long haul with no apu?
    Or a local truck with a pto?
  9. jmmtransportllc
    4
    Sep 27, 2024
    I’m assuming long haul. And it does not have a APU.
    snowwy Thanks this.
  10. dosgatos
    dosgatos Medium Load Member
    616
    1,320
    Sep 18, 2012
    With an X15, connect to Cummins Insite and look at the engine history.
  11. Lazer
    Lazer Road Train Member
    1,850
    2,984
    Jan 22, 2017
    When I drove for Sun Coast Resources, I was issued a straight truck that had 150,000 mi, with over 30,000 hrs. The truck started life assigned to ‘frac fueling’, then moved to local delivery as ‘hot fueling’ frac’s was dieing out. I pulled a 5,000 gal pup behind it, dang that was a nice truck, long-nosed Pete daycab, 18sp transmission, huge Cummins engine. Unfortunately, it had a single channel frame, developed a crack, and the company would not repair.
