Engine Locked Need Help
Discussion in 'Freightliner Forum' started by AFC, Aug 3, 2024.
  1. AFC
    AFC Heavy Load Member
    889
    1,177
    Jan 1, 2024
    Thank you! I will let the next road service know this. One thing, I didn’t see any engine protection warning or anything.
  3. AFC
    889
    1,177
    Jan 1, 2024
    lol! I’m not one of those guys. I just rebuild the head of my engine that was $14k I have 30k credit card and about $10k cash but a blown engine with down time after 6 months ago rebuilding the head is a little too much for a one truck guy that is trying to build a business. Also I just came off vacation so yes my cash flow is tight. I’m leased on to good company and work hard to make a living
  4. AFC
    889
    1,177
    Jan 1, 2024
    Thank you and will do
    Rideandrepair and Oxbow Thank this.
  5. NightWind
    NightWind Road Train Member
    2,718
    19,174
    Nov 11, 2006
    Sunny South, AL
    Well I am waiting with baited breath to see what the actual problem is. I am on the @AModelCat @Big Road Skateboard and @Rideandrepair team.
    Please keep us posted on your situation. Prayers for a fast and less expensive solution.
  6. AFC
    889
    1,177
    Jan 1, 2024
    Thanks. But when I parked the truck I put it in neutral. Am I understanding your response correctly?
    Rideandrepair Thanks this.
  7. wore out
    wore out Numbered Classic
    17,548
    219,290
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Easy if you got bearing problems the caps are black from heat….you smelled it when pan was off. Save money on less experience pay me now or pay more later it’s a simple deal
  8. AFC
    889
    1,177
    Jan 1, 2024
    I will let everyone know. Thank you
  9. AFC
    889
    1,177
    Jan 1, 2024
    Yeah ain’t that the truth. The oil pan had no debris and there wasn’t any smell.
  10. Big Road Skateboard
    7,281
    41,493
    May 2, 2021
    I've seen engines run minutes without oil pressure and not cause immediate damage
    I can't fathom that it happened here. Battery cables also run in that area. Possibly a damaged or broken + or - cable. You'd still hear the solenoid switch, but no movement.
    Hopefully this new guy has some experience and common sense.
  11. wore out
    17,548
    219,290
    Jun 5, 2013
    An experienced hand would have taken a set of bars and checked backlash and thrust on each rod as well as crank while pan was off. Would have zeroed in on the burnt smell and hot cap immediately. There would also be shiney flakes. Since there wasn’t and you did not smell anything burnt you’re most likely ok.
