I have a peterbilt 379 with a 12.7 detroit
The engine seems to idle and run fine but i can hear it missing and skipping in the exhaust ive tested the injectors changed a few feul lines that were leaking and changed both feul filters does anybody have any suggestions on why it wiuld sound like its missfiring in the exhaust but the engines sounds like its running smooth
Engine missing and skipping
Discussion in 'Peterbilt Forum' started by Pbarker, Jun 17, 2017.
How long since your last overhead?
Is it a Fitzgerald Glider?
Not likely. They stopped making 379s 10 years ago. Prebuilt gliders to avoid emission engines took off when the DPF started.
Believe it or not, until Daimler-Chrysler bought Detroit, Detroit's were available from every manufacturer. I had one in my 96 379, and have one in my 94 W900.HopeOverMope and Shock Therapy Thank this. -
Sounds like the Detroit stumble. R. Is this something new
Have you checked for soot near the exhaust manifold indicating an exhaust leak which sounds like a tapping noise? Also, and I doubt this is it, but a worn cam lobe would have excessive play in the lash and make a noise too. Truck may still pull well and run fine even with the worn lobe, only way to tell is to run the overhead.
Bean Jr. Thanks this. -
check bull gear if it gets loose it will start making this kind of issues
