Engine Modifications
Discussion in 'Lease Purchase Trucking Forum' started by scottmcc13, Mar 9, 2015.
  1. scottmcc13
    scottmcc13 Bobtail Member
    I have a t680 Lease through Swift. I was wondering where I can take the truck to have the engine power raised. I don't really care about the speed limiter, but I know this thing can run more horses than it's doing. I already put the 13sp in and that helps with some hills, but where do you recommend out of the swift network to have such work done?
  3. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
  4. Freddy57
    Freddy57 Road Train Member
    1,731
    8,246
    Nov 29, 2013
    Mount Vernon, MO
    Take it to an engine shop for the type of engine it has in it, such as Detroit or Cummins and have them upload the software for the higher horsepower rating. It costs a few hundred dollars but it's worth it if the power is turned down. Just make sure it doesn't breach your contract with Swift before you do it.
  5. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,383
    Jul 16, 2012
    Bentonville Arkansas
    Do you own this truck? If not I would wait in till you own it.
  6. MysticHZ
    MysticHZ Road Train Member
    5,910
    5,738
    May 28, 2010
    Exactly what is it you expect to achieve ... yeah you can turn up the power and go upgrade faster ... but all you accomplish is wasting fuel ... you making that much that you can afford to burn some dollars just so you can impress other drivers with how fast you can go up hill?
  7. Dakota1358
    Dakota1358 Medium Load Member
    431
    502
    Jun 15, 2009
    Staunton,Va
    Check your lease probably has a section about modification of any part of the truck.Usually if caught they will cancel your lease as its not really your truck and could void any warranty
  8. anotherjoe
    anotherjoe Medium Load Member
    390
    194
    Jan 8, 2013
    It will cause more soot build up due to more fuel burning . Cause more freq regens . really not worth it .
  9. anotherjoe
    390
    194
    Jan 8, 2013
    it takes a while to find sweet spot when driving alot of variables wgt etc. My friend drives a t680 10 sp with 3.25 geared rearend avg 8.3 + he keeps it between green shift point on the tach. with 200gal tanks he get awesome miles almost 1600 mi
  10. 77fib77
    77fib77 Road Train Member
    11,780
    78,079
    Jul 7, 2010
    St Louis
    Some times its better to carry more speed in the bottom of hill, so you get a better start at the next one.
