Engine mounts repeatedly breaking 2012 KW T700
Discussion in 'Kenworth Forum' started by MattH, Oct 2, 2018.
  1. MattH
    MattH Bobtail Member
    We have a 2012 KW T700 in which the motor mounts are repeatedly breaking. We have had to replace them 4 times in the last 2 months. Haul 3 or 4 loads and they break. We need to find a cause for this, but so far adjusting the clutch and changing the transmission brackets have not helped. Any help appreciated.
  3. AModelCat
    164,668
    Do the bolts fall into place or do you have to manhandle the engine with a prybar to get them to line up? If you're wrestling with the bolts chances are something is misaligned or bent, putting a shear force on the bolts.
    KB3MMX and Grubby Thank this.
  4. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    The parts in this country is a joke, if you think you found a deal that is great it probably is a knock off part made out of this country, buy the expensive oem parts that are made for real. instead of fake news we get fake parts anymore.
  5. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    The problem is even OEM parts for American vehicles are outsourced to other countries to produce.
    KB3MMX, tommymonza and Grubby Thank this.
  6. pmdriver
    2,338
    3,503
    Nov 14, 2017
    I really do not care if they are outsourced, all I want is quality. Used to be pride in this country, now it is seeing if they can slide doing half way jobs. We need to start acting as #1 again instead of #2
  7. Grubby
    Grubby Road Train Member
    2,475
    135,505
    Aug 30, 2016
    Fostoria Ohio
    Yep, my moneys on somethin bein in a bind. Is it both side or?
  8. Brandt
    Brandt Road Train Member
    4,625
    6,359
    Sep 17, 2012
    Have you ever change the crankshaft dampner ? They wear out and stop working, then all that energy go Thru the truck and part keep breaking.
    Lots of people will say they never wear out and most people never change them. People can never figured out why bolts are breaking for no reason and other parts. Pittsburgh Power say they are only good for 500,000 miles.
    It might be the answer to you problem.
    KB3MMX Thanks this.
  9. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,358
    Nov 1, 2017
    The Sticks, Idaho
    No disrespect intended, but... Does tje driver know how to drive it properly???
    Had a guy at my old place of employment that was constantly breaking motor mounts... Finally someone followed him with a set of binoculars and discovered he was hot rodding the crap out of the truck every chance he got once he was out of sight of the main yard, over reving engine and jammimg gears to the point it would nearly lift a steer tire off the ground... Miracle he didnt break anything else.
    KB3MMX, Cam Roberts, x1Heavy and 2 others Thank this.
  10. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Most all bolts made have a rating on them among other things.
    Use bolts that are rated higher than can be generated by the engine and you are in good shape.
    I am led to understand we are infusing bolts at forging (I think it's BS because forging is not the same as pouring raw)
    I learn towards driver abuse. This is one set of bolts I don't bother much in a 18 wheeler.
    KB3MMX, Cattleman84 and Cam Roberts Thank this.
