Engine numbers not adding up part 2
Discussion in 'Ask An Owner Operator' started by dis_bit, Aug 4, 2022.
  1. dis_bit
    dis_bit Bobtail Member
    18
    11
    Jan 27, 2021
    I feel like maybe I haven't explained the situation well, so I want to add some details. The engine that is in our truck isn't the engine that is supposed to be in it; worse, as far as we can tell, the engine in our truck cannot LEGALLY be in it, as it is a 1993 pre-EGR, and the engine that was supposed to be in our truck at the time of sale was a 2003 EGR per the re-man number associated with our VIN. It seems pretty clear that at some point, prior to our purchasing this truck, the engine was swapped. Am I correct in believing we can't use the engine in our truck? Am I wrong in believing this is fraud? And if it is fraud, what are my next steps? We are trying to get the build sheets now.
  3. AModelCat
    164,942
    Not sure how this could be fraud. Dollars to doughnuts the original engine went BOOM! at some point and the owner at the time just swapped in the one that's in there now. Quite common to swing a new/reman/used running engine if the original block does not meet suitability criteria for a rebuild.
    Engines (I believe) were required to meet the new emission standards in the later half of the 2002 ENGINE model year (not chassis model year). It is quite possible that a pre-emission engine was factory installed in an early 2003 chassis.
    Wasted Thyme and jamespmack Thank this.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,574
    9,934
    Mar 30, 2014
    My understanding is there were, for the most part, no 2003 and 2004 engines. Again, I said for the most part, so don't attack me for the oddball engines. All the manufacturers and consumers were concerned about the upcoming EGR engines, so they made nearly 3 years worth of 2002 engines. The reman shouldn't be proof, but if you're talking about a PACCAR truck, I'd be willing to bet a lot of money that it did not have a 2003 engine in it.
    wore out, Last Call and AModelCat Thank this.
  5. Bean Jr.
    5,574
    9,934
    Mar 30, 2014
    Ok, I reread your other post. It is a glider and it had a 2003 EGR engine originally installed, or it was a 2003 reman?
  6. Bean Jr.
    5,574
    9,934
    Mar 30, 2014
    And truthfully, I doubt in a glider you will run foul of the epa unless the glider was assembled after the new epa regs.
  7. AModelCat
    164,942
    If its a true glider you're golden.
    Diesel Dave, motocross25 and Bean Jr. Thank this.
  8. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    What's the vin number? If it's a glider it's easy to tell by the VIN. Otherwise swapping an epa engine or a non epa engine is illegal. Make the dealer make it right or sue to either buy the truck back or put the correct engine in.
  9. dis_bit
    18
    11
    Jan 27, 2021
    It is supposed to be a 2002 re-man in our truck; but the engine actually in our truck is not the engine associated with our VIN. The re-man plate is for a block that has been converted to DDEC 4; our block is absolutely not converted, nor is it ready for conversion.
    We have a 2018 Freightliner chassis, the block currently in it is a 1993 detroit series 60 DDEC 2. Can we legally patch this engine, and keep running paper log and non-DEF?
  10. Long FLD
    Long FLD Road Train Member
    12,938
    54,302
    Mar 4, 2015
    Is it a true glider or not?
  11. dis_bit
    18
    11
    Jan 27, 2021
    I am not sure how to answer, except to explain that our chassis went from Freightliner to Fitzgerald to be fitted as a glider. The re-man number on the plate on our block is the re-man number Fitzgerald assigned to our VIN, for a 2002 series 60 DDEC 4, a Glider. The engine this plate is attached to, however, is NOT a 2002 DDEC 4. Going by the number stamped directly into the block, it is a 1993 DDEC 2, it is not converted, and it has never been associated with our VIN. So, according to our VIN, yes, the truck is a glider. But the engine in it? No clue.
  12. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    Fix your engine and get back to work..
    Because it has a newer engine vin according to the truck vin maybe that's a gray area to put and older motor in it, but a 2002 model with egr isn't really an emissions motor anyway. And no one is gonna know you did anything different with the original motor either. When was the last time you saw EPA doing roadside inspections. Fix and get to work
    jcatel, nikmirbre, Oxbow and 4 others Thank this.
