Engine oil consumption
Discussion in 'Experienced Truckers' Advice' started by Mandeepsingh, Jun 15, 2019.
  1. jamespmack
    216,478
    That is the issue, not so much as the engine. I think they all could be good engines without. Really put a hose in your butt, then put it in your mouth and go for a run. Same thing.
    FlaSwampRat and singlescrewshaker Thank this.
  3. AModelCat
    164,644
    Lets go for the most expensive option right off the bat.
    SMH
    @jamespmack has the right first step. It may just stabilize at or just over the low mark on the stick.
    jamespmack Thanks this.
  4. jamespmack
    216,478
    Seen a couple N14, E model cats with miss marked dip sticks. Drove you nuts to keep it full. Let it half way between add and full the didnt use oil.
    FoolsErrand, Dan.S, magoo68 and 2 others Thank this.
  5. woolybully35us
    woolybully35us Medium Load Member
    313
    550
    Mar 13, 2015
    ks
    my isx uses 0 oil between oil changes. I change mine ever 10000 miles. I use Mobil delvac 1300, if I use anything else it will use 1 to1.5 gal. between oil changes. it had a in frame at 1,100,00 miles. it has 467,000 on it now.
    bzinger, swaan and jamespmack Thank this.
  6. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    If you quit putting in a quart at a time it may not use any oil at all, let it get to the add mark before topping it off.
    Then make sure your turbo is not weeping oil and your air comp is not using it either.
    Like mentioned above, try a different oil too. My frame is marked delo, but the engine don't like it.
  7. bzinger
    bzinger Road Train Member
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    My companies fleet hasn't experienced this with the 2015 isx engines ( 100 trucks on 30k drains ) and no idle time .
    12s and 13s were known for carbon packing in the rings which polished the liners leading to insane oil consumption.
    Had my 13 tore down at 684k for the same issue and yep the liners were polished.
    Cam and followers were flaked also but light varnish and no sludge .
    Everything updated and no issues since .
    Mine started guzzling oil around the 550 mark and only got worse .
    @ deveinarizona has a 12 and hasn't experienced any of this .
    I think it has to with idling.
  8. singlescrewshaker
    4,853
    42,408
    Dec 31, 2017
    Little Havana, FL
    1.1 million before 1st overhaul.! That's pretty good. What year is your ISX? They were around what, about 4 years before egr.? Then all the other bs they've been forced to hang on them..
  9. woolybully35us
    313
    550
    Mar 13, 2015
    ks
    mine is 06 cm870 great engine
    singlescrewshaker and jamespmack Thank this.
  10. Snow Monster
    Snow Monster Medium Load Member
    543
    1,297
    Feb 9, 2019
    I agree, don't add any oil until it's down a gallon, or to the add mark, sometimes they find their own level and stay there.
    Also agree, change the oil every 12k to 15k as many engines I drove never used oil, except when they got close to time for an oil change, they would use some oil which was a sign to do an oil change.
    A restricted air filter will cause some engines to use oil.
    Another thing to consider, or discover, which I've seen a few times, is a new engine starting it's life in a cold climate thatd was not worked hard enough or was idled a lot before it had any real miles on it.
    The piston rings don't expand enough to properly seal or develop a wear pattern and the cylinder walls become polished.
    One truck I drove that had not been properly broken in during cold weather used a gallon of oil every 500 miles like clockwork, but the leasing company just kept handing me jugs of oil and weren't interested in fixing it.
  11. Mandeepsingh
    Mandeepsingh Light Load Member
    63
    23
    Aug 30, 2018
    First of all, thanks everyone for the help. I really appreciate it. But like @Snowmonster said reagrding the air filter. I just changed my air filter also because it had ‘16 date on it. Do u guys think that i could have been because of my air filter or no?
