Engine oil consumption
Discussion in 'Experienced Truckers' Advice' started by Mandeepsingh, Jun 15, 2019.
  1. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I dont think so. Change oil brand first.
    Then go from there.
  3. frito bandito
    frito bandito Light Load Member
    124
    457
    May 31, 2019
    I wouldn't worry about the brand as long as it's minimum CJ-4. Can you afford an inframe? Just keep an eye on it.
  4. Snow Monster
    Snow Monster Medium Load Member
    543
    1,297
    Feb 9, 2019
    If the air filter was badly restricted, you should be able to tell.
    The truck should pull better, the engine should run a little cooler, your fuel mileage should improve at least slightly, your gauges will tell you.
    I drove through a dust storm one time with a freshly serviced truck with a brand new air filter and 800 miles later it needed to be replaced.
    When diagnosing a problem, eliminate the cheap stuff first, like filters.
    If it turns out you need an in frame or something else major, you're going to want a new air filter anyway.
    An afterthought, make sure crankcase is venting properly.
    I'm an old guy, don't know what the kids call it these days, but in my time they called it PCV, positive crankcase vent.
    Good luck.
    stillwurkin and Mandeepsingh Thank this.
  5. rick4755
    rick4755 Bobtail Member
    Jun 16, 2019
    100% right. And it will clog DPF in the mean time
    jamespmack and swaan Thank this.
  6. Mandeepsingh
    Mandeepsingh Light Load Member
    63
    23
    Aug 30, 2018
    hey sir,
    I gotta ask u something. I m getting an overhaul and just wanted to know whats the best time to get a delete after an overhaul? Any advice would help. Thanks
  7. AModelCat
    164,574
    Just a few points to be aware of if you delete:
    -Any warranty from the rebuild will be null and void.
    -Apparently its very hard to find shops that will work on deleted trucks.
    -Many deletes are hack jobs with crappy programming. A bad delete will kill that rebuild loooooong before the emission equipment will.
    I will speak no more about this since discussing how to, where to and who does deletes is a subject the TTR Forum owners don't want discussed on their website.
    mhyn and snowwy Thank this.
  8. balliworld
    balliworld Bobtail Member
    21
    6
    Apr 25, 2019
    LOL, good catch. now it's his own truck and, he is paying attention lots of attention. company truck never really bothered.
    bzinger Thanks this.
