Engine oil dye
Discussion in 'Ask An Owner Operator' started by pavrom, Jul 26, 2021.
  1. jason6541
    jason6541 Road Train Member
    2,425
    5,367
    Mar 5, 2012
    Omaha, NE
    Yep, mistress’ always gets the time and money first.
  3. bad-luck
    bad-luck Road Train Member
    3,443
    6,352
    Nov 16, 2013
    Baltimore, Maryland
    Me personally, I wouldn't add something like that to you engine oil. I am sure they say its safe, but I would not trust it.
    Diesel Dave, feldsforever, 201 and 2 others Thank this.
  4. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    If you can't spot a oil leak, coolant leak, freon leak.
    Should probably get your eyes checked.
    They're all colored and leave traces.
    feldsforever Thanks this.
  5. pavrom
    pavrom Road Train Member
    3,218
    7,426
    Apr 29, 2012
    NE illinois
    When whole side is covered in oil from top to bottom and never been washed in a while it can be head gasket , front cover seal , compressor gasket , oil pan , hoses etc
    I know major leak at head but wanna make sure that all taken care during repair
  6. pavrom
    3,218
    7,426
    Apr 29, 2012
    NE illinois
    Whats wrong with fixing the equipment ?! I like my equipment to be in good working order and looking clean at the same time
    jason6541 Thanks this.
  7. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    Call Cummins and see what they use. I know they do that to find leaks to be 100% sure when quoting a job.
    pavrom Thanks this.
  8. Big Road Skateboard
    7,186
    40,795
    May 2, 2021
    Easy to find leaks on a clean engine. You know a car wash is like a buck?
    Diesel Dave, feldsforever and snowwy Thank this.
  9. 201
    201 Road Train Member
    12,814
    26,381
    Apr 16, 2014
    high plains colorado
    I'm not saying there's anything wrong with wanting equipment right, I did the same thing, HOWEVER,,,that was 20 years ago when repairs didn't break the bank. I give you a lot of credit ( credit not available in most areas) trying to make a go of it today. Yes, it shows an incredible amount of pride, something lacking today, and to even make it today you must go up and above what we did. Not to take the wind out of your sails, but it's inevitable, O'O's will be forced out, I saw it was beginning to tank, and wanted no part of it. As proud as I was, I didn't want to do it for nothing, and I think you'll cross that bridge eventually.
    pavrom Thanks this.
  10. Lazer
    Lazer Road Train Member
    1,850
    2,983
    Jan 22, 2017
    If it’s that dirty, after you wash it off, even Mr Magoo should be able to see where any leaks are. IMHO
    snowwy and feldsforever Thank this.
  11. MTN Boomer
    MTN Boomer Road Train Member
    1,157
    1,960
    Feb 4, 2019
    I have heard that since the beginning, put 2 gallons of Lucas uin it and run it
    201 Thanks this.
