Engine overheating
Discussion in 'International Forum' started by ivydonw, Feb 19, 2015.
  1. ivydonw
    ivydonw Bobtail Member
    Saint Louis, Missouri
    I have a 1997 International with a Cummins M11 engine. Yesterday as I was driving down the highway I noticed that it was getting cold in the cab. As I passed my hand over the heater vent I discovered that it was blowing out cold air. I then checked my gauges and found that the water temperature was almost at 230 degrees. I got it to the shop and the coolant was not low, but found that it had oil in it. Does any one have any suggestions as to what may be wrong?
  3. Dryver
    Dryver Road Train Member
    2,818
    2,576
    Nov 30, 2008
    Sioux Falls, SD
    Head gasket? Is they coolant in your oil?
  4. passingthru69
    Yep, Sounds like a head gasket blown... Be careful or you might end up chucking the motor if you run it too long that way..
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    had same thing happen about a month ago on the coldest day too in the single digits. 1 or both thermostats were stuck closed. or sticking. 6 degrees & my temp was going to 210 ?? and no heat? something was not right. but after putting engine fan on while parked took a few min for temp to come down. drove 100 miles back home & the temp fluctuated but never got too high, 170 to 200 all the way back. replacing of thermo's fixed it.
    if you lost no coolant, than I would guess it is prob not a head gasket. I could be wrong. when my head gasket blew it blew coolant of of the overflow hose attatched to the coolant tank.
  6. WitchingHour
    WitchingHour Road Train Member
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    Could be your injector cups are cracked.
  7. ivydonw
    Thanks everyone, it sounds like this is beyond my capabilities, so it's off to International shop. I hope it isn't the head gasket or worse.
  8. WitchingHour
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    Better a head gasket than the injector cups. I hope for your sake I'm wrong about this.
  9. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Oil cooler would be my guess.
  10. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    i was kind of thinking oil cooler first. do you know if the oil got there while the motor was running or after you shut the motor off?
  11. Heavyd
    7,826
    6,276
    Feb 4, 2009
    This is kinda screwy. When the engine is running, oil pressure is normally 40-50 psi or so and coolant pressure is about 7-10 psi. If the oil cooler leaks, oil will get into the coolant because the oil is higher in pressure. Once you shut off the engine, the oil pressure is zero, but the hot coolant stays at about 10 psi for a while until it cools down. During this time the coolant will leak into the oil.
