Engine overspeed code?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Richter, Aug 29, 2013.
  1. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Im getting code
    # ID FM CNT
    2 85 01 91
    Im not sure what numbers im supposed to search for in the manual, because the manual has 4 lines wide and 2 of these numbers are just frequency and the number of codes. (i think) 85 comes up with engine overspeed. Did I search this right? What does that mean. Is this bad? It came up while idleing at 750 rpm. I also have code 1 95 0 58 active and have seen that one a lot. i need to get this truck into service, to get these fixed, but in the mean time can i idle the truck without damage? Its 95 degrees out here.
    Thanks
    P.S.
    This is a Detroit s60 in a 06 fl columbia
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    I can't really help you, I have no idea what truck or engine you have. 85 is an engine over speed code for Detroit engines, but FMI 01 does not make sense, FMI 01 means data is valid, but below normal operating range. All I can tell you on your second code is that FMI 0 is data valid, but above normal operating range.
    Tell me what kind of truck and engine and I may be able to help.
  4. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    edited on bottom, sry i forgot that.....fl columbia s60 detroit
  5. Rawze
    Rawze Medium Load Member
    328
    818
    Jun 29, 2013
    inmytruck
    engine overspeed (maybe bad cam sensor) and Wiring harness code.
    Richter Thanks this.
  6. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    what does that mean? Can i run the truck without damage?
  7. Rawze
    328
    818
    Jun 29, 2013
    inmytruck
    yeah,...just be careful of surging going down the road. The second code is a fuel restriction code,...its telling you your filter(s) are clogged. Perhaps bad wiring harness as well, or bad filter, or bad sensor.
  8. lester
    2,957
    8,086
    Jan 2, 2012
    NW, Iowa
    Yes.......
  9. Rawze
    328
    818
    Jun 29, 2013
    inmytruck
    I am not nearly savvy on detroits, but I did take the time to collect a bit of info on them when considering what truck to buy a while back. One problem I see is that the codes are not consistent from one model to the next, nor within the same model in different applications. can be confusing finding the right codes on them.
  10. GrapeApe
    2,215
    2,212
    Jan 7, 2013
    95/0 is part of the maint alert system, it's shows when the fuel pressure differential pressure falls below the calibrated limit. Basically it's saying that the fuel filter has a high restriction. If a new filter doesn't fix it, then you'll have to get it checked out.
    85/1 is still confusing me, a typical engine over speed is 85/0. I don't even show a listing for 85/1. I'd have to suspect an wiring issue. Possible bad bad SRS sensor, but they usually set a code for too many missed signals
    You FM # is the FMI (failure mode identifier). They are an SAE standard for all codes as follows:
    00 Data valid but above normal operational range
    01 Data valid but below normal operational range
    02 Data erratic, intermittent, or incorrect.
    03 Voltage above normal, or shorted high.
    04 Voltage below normal, or shorted low.
    05 Current below normal, or open circuit.
    06 Current above normal, or grounded circuit.
    07 Mechanical system not responding properly.
    08 Abnormal frequency, pulse width, or period.
    09 Abnormal update rate.
    10 Abnormal rate of change.
    11 Failure mode not identifiable.
    12 Bad intelligent device or component.
    13 Out of Calibration.
    14 Special Instructions.
    15 Reserved for future assignment by SAE.
