Engine Power Shortage, Turbo Problems etc. No engine light - D13 780
Discussion in 'Volvo Forum' started by Pawel-pl, Aug 20, 2018.
  1. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    late when i posted
    Reason for edit: delteted message as it was late when i posted
  3. Pawel-pl
    Pawel-pl Light Load Member
    66
    30
    Jul 3, 2017
    Yes we checked injectors on the computer. First cylinder injector doesnt show any activity when you turn it off and on, all of the other ones are good. We are still checking what is causing the engine shaking etc.
    The turbo had to be programed as the VGT was not changed,
    I will post later on when know whats happening.
  4. Pawel-pl
    66
    30
    Jul 3, 2017
    So finally I have the result to the whole issue.
    What came out as problem maker is that 2 of the air intake valves on cylinder one got burned out and damaged. First one was just gone and 2nd one wasnt closing. I got cylinder head regenerated with all new valves etc. The reason behind it could be that the 7th injector was leaking fuel to the system all the time, at least thats what the mechanic said.
    So what got replaced is - turbo, 7th injector, cylinder head regen with all new valves etc., cylinder one injector, def pump, seals on the engine.
    Total cost about 15k not including the one guy that ####ed up the turbo installation in first place.
    Truck is running as new :D
    Problem Solved, Thanks for all ideas and info.
    QUALITYTRUCK Thanks this.
  5. uzb-trucker
    uzb-trucker Bobtail Member
    10
    Hi there,I have same problem, with Volvo Vnl730 D13 I-shift, it started after I changed the oil,and leveling valve. Before was fine no problem, Issue happens after driving about 60 miles speed goes down and gas pedal doesn’t respond no rpm, I have to pump the gas pedal and it’s slowly shaking and keep driving , then after few miles it repeats again, no engine light or fault codes, sometimes check transmission message pops out, I went to Volvo they said inactive bunch of faults related to transmission, already changed the boost sensor and fuel filters, turbo works fine, any idea please help
  6. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    Use the search feature in the upper right hand corner of the page. Type "data link"........
    Newto Trucking Thanks this.
  7. uzb-trucker
    10
    Hi I did and there is lot of data link options, which one ?
  8. DANICEK
    DANICEK Bobtail Member
    8
    An expensive fix
  9. DANICEK
    8
    I guess mine has the same issue
  10. MaxK123
    MaxK123 Bobtail Member
