Engine replacement with smaller displacement motor?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by alfio, Mar 23, 2025.
  1. alfio
    alfio Light Load Member
    70
    34
    Jun 2, 2021
    Hello all,
    Strange question but bear with me pls.
    I have a chance to buy an International with a dead Maxxforce 13. I have a good running (all mechanical) DTA360 (5.9L) from an older truck. Newer truck has a 10 speed. To be clear, I am not wanting to use this to pull 53ft trailers or anything similar. Basically, would be wanting to use it as a big pickup truck. Would delete first axle, throw a flatbed on it, and use it to move equipment for my business (heaviest load is 10k lbs or so).
    The DTA360 should fit no problem in the newer truck and I'd gain a bunch by moving into a newer chassis. Downside would be ending up with an unusable underpowered setup.
    Go for it? Or terrible idea?
  3. AModelCat
    164,646
    I doubt you'd be happy with less than half the HP and nearly 1/3 of the torque.
    You'd be in for some pretty extensive fabrication work, along with probably rewiring much of the truck. All the electronic modules on the truck will likely be wanting to communicate with the engine ECM, which would no longer exist.
    W923, alfio, Arctic_fox and 2 others Thank this.
  4. 201
    201 Road Train Member
    12,779
    26,296
    Apr 16, 2014
    high plains colorado
    Well, I'll tell ya', it's better to have the power and not need it, than t'other way 'round. However, what you plan to do seems totally legit, and it's all about saving money today, I say go for it.:thumbup:
    W923, alfio and Bean Jr. Thank this.
  5. Arctic_fox
    4,509
    25,470
    Sep 16, 2016
    Cat has the right of it. Its doable and would likely work. But its going to be very underpowered, very slow, a lot of the fiddly bits wont work. Its going to be VERY heavy for a pickup and likely get stuck pretty easy or bogged down if heavy and an absolute metric #### ton of work to get everything working.
    If you do it yourself it COULD be worth it. But i think you would be happier finding an old generic F250 or maybe an old box truck or uhaul. Some such like that and cutting the bed or box off for a flatbed. It wouldnt cost a lot more, would be WAY easier to fab and likely cheaper on the backend.
    W923, 201, broke down plumber and 2 others Thank this.
  6. OLDSKOOLERnWV
    19,131
    289,253
    DT is a good engine. The 360 will be slow, but, it will be dependable. Shame it’s not a 466….
    W923 Thanks this.
  7. kylefitzy
    kylefitzy Road Train Member
    4,753
    19,804
    Aug 12, 2007
    Kansas city,Mo
    I don’t know any specifics about your truck and engine combo.
    That being said I drove a 26k gvrw dump truck with a 5.9 Cummins with an auto transmission years ago. That was the most under powered, slowest truck I’ve ever driven. To the point it was unsafe driving down the highway. Fully loaded with a slight uphill on ramp I could get it up to about 30-35 by the end of the ramp, merging onto a 70mph interstate. Any slight hill and I was down to 50.
    How much of that was the 5.9 and how much was the automatic transmission? I’m not sure but that truck was a DOG.
    W923 and ElmerFudpucker Thank this.
  8. ElmerFudpucker
    7,011
    76,628
    May 17, 2024
    I own that truck. It’s definitely an in town truck. Put 10 ton of rock on it. You get there, eventually. I personally think it’s the 4 speed auto that makes it such a dog.
    W923 and kylefitzy Thank this.
  9. W923
    W923 Road Train Member
    1,419
    4,389
    Feb 28, 2022
    I got one of them too old f700 flatbed with a 4 speed Allison
    Put one super sack of sand on it and forget passing anything put 3 on and passing granny on a bike is a challenge…. It’s gonna be upgraded to a mt 653 soon since I just pulled one out of a truck we are parting out so I guess we’ll see
    kylefitzy and ElmerFudpucker Thank this.
  10. ElmerFudpucker
    7,011
    76,628
    May 17, 2024
    Let me know how that goes, because I was either wanting a 653 or just doing a manual swap
    W923 Thanks this.
  11. W923
    1,419
    4,389
    Feb 28, 2022
    I was going to swap the auto for a manual until this came up….should be considerably less hassle since I don’t have to add a clutch linkage.
    I will have to change the flywheel housing to sae2 instead of the 3 that’s on there now unless I can use an adapter.
    ElmerFudpucker Thanks this.
