Engine Replacement
Discussion in 'Freightliner Forum' started by Notsoheavyhaul, Jul 1, 2020.
  1. Notsoheavyhaul
    Notsoheavyhaul Bobtail Member
    I have a 2011 Cascadia with a siezed motor. It's a DD15 . want to know if a 2017 DD15 would be a compatable swap. What are the problems I need to be aware of? Thanks in advance
  3. PE_T
    PE_T Road Train Member
    You might want to consider buying another truck. I hear they’re dirt cheap right now.
    Diesel Dave Thanks this.
  4. MTN Boomer
    MTN Boomer Road Train Member
    1,157
    1,960
    Feb 4, 2019
    Might ask in the Mechanics forum.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Different emissions system yours is air operated, newer ones are electrically operated.
    Maybe if you kept your computer's in place it would work.
  6. RocketyMan
    RocketyMan Medium Load Member
    554
    337
    Jun 5, 2015
    You would need the whole engine harness to be in tact, the associated MCM on the GHG17 engine, the ATS of the same vintage with same ACM vintage, you would need the 500k CPC4 of same vintage, you would need to convert the J1939 backbone to 500kbaud, you would need a 500k ICU4me...the associated PT wiring, a 500k CGW...500k ABS... and hopefully you run a manual trans too. You'd also need to have compatible SAMcab and SAMchassis with the 500k CGW as well regardless the SAMs CABINCAN--meaning those would need to be upgraded as well.
    daf105paccar and QUALITYTRUCK Thank this.
  7. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Are block ,pistons and head the same?
    Could he swap only the bare mechanical parts?
  8. Diesel Dave
    9,729
    33,297
    Jan 20, 2010
    Hesperia, Ca.
    I just bought a 2014 Pete 388 short flattop sleeper with a ISX 15, 13 speed for 22k cash.
  9. RocketyMan
    554
    337
    Jun 5, 2015
    I'm not sure exactly on everything. But I do know the intake strategy is different between the two. I'd be curious too...
    daf105paccar Thanks this.
