Engine rotation direction
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by insanityeight, Mar 14, 2020.
  1. insanityeight
    insanityeight Light Load Member
    291
    113
    Jul 26, 2013
    birmingham al
    So im trying to do valve adjustment on epa10 paccar mx 13 without barring tool to turn flywheel. Is it ok to turn engine in reverse if its easier and if so how will that affect adjustment process?
  3. Slapout okie
    Slapout okie Bobtail Member
    6
    4
    Oct 8, 2019
    If you turn the engine in in opposite direction the timing of all gear or chain drive components will be off due to backlash being incorrect. Bite the bullet and have a certified paccar shop do it. That way you have warranty on work
    AModelCat Thanks this.
  4. AModelCat
    165,111
    If you bar an engine backwards most manufacturers recommend barring it in the correct direction X amount of degrees (I've seen a wide variation of degrees from 45 to 180, check the appropriate service literature for confirmation) in order to take the backlash out. In all honesty, its easier to just turn it the proper direction.
    insanityeight and spsauerland Thank this.
  5. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Harbor Freight sells a 3/4 drive set cheap! A barring tool is just a 3/4 ratchet and cheater pipe, if you plan on doing your own work you'll be happy to have that ratchet more than once.
    insanityeight Thanks this.
