Engine still slamming after motor mounts replaced
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rjbailey, Jun 19, 2020.
  1. Rjbailey
    Rjbailey Bobtail Member
    5
    Jun 19, 2020
    Hi guys, new here. I have an 03 freightliner century with an isx450 Cummin . Recently replaced all motor mounts and still feeling the engine slamming bck when I take off in 1st and 2nd gear while loaded. U joints are fairly new. Carrier bearing fairly new. Driveshaft tight. Any suggestions on what the issue maybe?
  3. SWMO_Transport
    SWMO_Transport Bobtail Member
    22
    35
    Feb 11, 2018
    Have you made sure your 5th wheel jaws are adjusted tight enough? Sometimes you can feel the trailer slide forward when braking and backward when taking off if your jaws are a little loose. Also, some 5th wheels are adjustable and some are not.
  4. bad-luck
    bad-luck Road Train Member
    3,438
    6,331
    Nov 16, 2013
    Baltimore, Maryland
    Spring u bolts, rears?
  5. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    If you set the brakes and act as though you are trying to lift a load, ( trying to get moving) does your gear shift lever flop from to the side? Thats a sign of a broken or loose motor mount. I see you said they were replaced. Mayby someone forgot to tighten a bolt? If its while moving others have already covered that scenario.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    A clutch with hot spots or bad springs will do that. Check everything else first.
    Found some work better with just a touch of throttle and easy off the clutch. Yes that is slipping it just a bit. Against what I was taught but I had to drive it and that worked.
    Dino soar, Ffx95, PE_T and 1 other person Thank this.
  7. Deere hunter
    2,121
    10,024
    Aug 5, 2017
    Shallowater Texas
    ^^^^^^^^clutch yes^^^^^^^^
  8. woolybully35us
    woolybully35us Medium Load Member
    313
    550
    Mar 13, 2015
    ks
    fifth wheel will make it jerk an bang when you take off.
  9. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Ya, are both sides of the "squares" fully clicked in.
  10. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    If after you grease the 5th wheel it gets bad you may need to have the 5th wheel jaws adj. most shops have a pin on a weld on arm that they use to adj. it to where it is tight but will still let you pull the unlatch with/out it hanging up and being hard to get unlocked?
  11. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Check your suspension. I had a broken spring underneath an axle that caused a similar problem for me. It was in a place where the break wasn't visible during inspections. It finally pulled free, and I found the problem when I was backing into a dock. I noticed that the drive tires weren't parallel because the axle was offset by about 2 inches.
