Engine still slamming after motor mounts replaced
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rjbailey, Jun 19, 2020.
  1. Rjbailey
    Rjbailey Bobtail Member
    5
    Jun 19, 2020
    Hey guys just wanted to say thanks for the info. It's my fifth wheel. Going to replace tomorrow. again thank a lot for all the replies
    bad-luck, 46/71 Hybrid, PE_T and 2 others Thank this.
  3. Rjbailey
    5
    Jun 19, 2020
    Hey guy . Back again. 2003 freightliner century isx450 Cummins I have replaced rod and main bearings. Oil pump, oil pressure sensor and oil pressure sensor wires. I will get a low oil pressure sensor warning maybe once or twice a week then it stops. Again I'm new to trucking and still learning and I have replaced everything I've been told to replace that the problem could be coming from. Can anyone help
  4. bad-luck
    bad-luck Road Train Member
    3,459
    6,384
    Nov 16, 2013
    Baltimore, Maryland
    Did you try and adjust your 5th wheel btw?
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,563
    6,649
    Aug 26, 2014
    I would want a manual gauge on the mirror showing what the pressure really is. Also would want to know if the engine has the correct amount of oil in it. Is the oil to the full mark. Is the dipstick correct. Oil capasity can be looked up by engine number.
    AModelCat Thanks this.
  6. AModelCat
    165,416
    Like BoxCarKidd said. Get a test gauge on it. I'd hate to hear it was just a damaged wire and you threw thousands into it.
    BoxCarKidd Thanks this.
