Engines for 18 Speed Eaton
Discussion in 'Trucks [ Eighteen Wheelers ]' started by vijay, Mar 8, 2012.
  1. vijay
    vijay Bobtail Member
    39
    Jul 18, 2011
    California
    I have a quick question. I need to know what engines are out there that are compatible with 18 speed eaton. And also how much do they cost new? and possibly used ones as well( with at least 50 % life left)?
  3. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Why do you want an 18?
    Planning on heavy haul or what?
  4. melpromud
    melpromud Medium Load Member
    463
    114
    Jan 29, 2010
    camden ny
    Their all compatable. It make no difference what engine you have.:biggrin_2554:
  5. vijay
    39
    Jul 18, 2011
    California
    Awesome, this will go behind a C12 or C10. I have yet to evaluate ISX option.
  6. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    Usually the folks that need an 18 have the bigger engines for the HP and torque, you don't often see the smaller engines, especially for on highway applications with an 18.
  7. The Challenger
    The Challenger Kinghunter
    7,127
    3,367
    Dec 22, 2007
    East Central FL
    You have got me very curious Mr. Vijay. What do you plan on using an 18spd mated with a C12 or C10 with.
    KH
  8. vijay
    39
    Jul 18, 2011
    California
    Hello KH, long story short, I cannot stand auto trans. I recently found someone close by ( junkyard) that is trying to sell a 18 speed, dirt cheap. It is a bit too much for my needs but since I can skip shift, I'm all on it. My travel is all h/w ... :biggrin_25516:
    The Challenger Thanks this.
  9. Marc Letourneau
    Marc Letourneau Light Load Member
    119
    26
    Feb 23, 2012
    Worcester Massachusetts
    The 18 speed is a great transmission, Shifts very nice and goes good with 3:73's in my opinion.. I don't think you will be disappointed..
  10. Bigd41302
    Bigd41302 Bobtail Member
    4
    Little overkill there if you ask me. The eaton 13 and 18 speed are the same transmission with a different shift knob. The 18 speed allows you split in low range and high. While the 13 only splits in the high range. The Eaton 13 speed in my opinion is the best choice for on highway application. Only time you would benefit fron the 18 is if you were heavy and needed the split on the low side to keep the engine in the torque curve.
    Also swapping an auto shift to a manual is not just swap and go. You have driveline length, air, electrical, etc. that must be accounted for. It can be done, just do your homework on the swap before you go buying a junkyard tranny.
  11. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Just as Bigd said. An 18 would make a cool playtoy trans but there will be work involved to make it work.:biggrin_25514:
