EPA Crackdown on Deleted Trucks
Discussion in 'Trucking Industry Regulations' started by Shaggy76, Sep 17, 2019.
Thread Status:
Not open for further replies.
  1. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    All you owners that had anything to do with PDI to get your delete kits, you may want to get your trucks back to stock. First Bully Dog was hit with massive fines last year, then Volkswagen, then Spartan, and now PDI. They are hitting the bigger shops with several small shops in between. They even fined mechanics at $5,000 for working on the trucks that had delete kits. I will add the links for more info below.
    Also do note that Daimler sent a memo around today (which is how I learned of this and had to look the info up myself) that their new policy effective immediately is if a truck comes into the shop and after signing a waiver on the repair order that the emission system has not been tampered with, then they see that one has been tampered with, the work is supposed to stop right there and the customer is to be contacted to return the truck to stock or the owner is to pay for the work done and the truck is to be towed from the shop. Daimler is not taking a chance for the OE, the shops, or their technicians with the possibility of fines.
    If you guys have delete kits on your trucks or these special tuners, you can expect shops to not repair your vehicles anymore, especially after today. The 2019 Clean Air Act, Vehicle and Engine Enforcement went into effect on January 1 and the subsection that allows not only penalties, but damages and going after mechanics for those same penalties went into effect September 1. The crackdown has begun.
    2019 Clean Air Act Vehicle and Engine Enforcement Case Resolutions | US EPA
    Performance Diesel, Inc. Clean Air Act Settlement Information Sheet | US EPA
  3. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Nothing like a little government overreach, or in this case a lot.
  4. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    good.
    I like clean air
    simonsocm, KansasWhirl, PE_T and 7 others Thank this.
  5. bryan21384
    bryan21384 Road Train Member
    15,732
    34,268
    Sep 18, 2009
    Memphis, TN
    No government overreach. Us civilians put them in power, often times without being educated on what they stand for. Many of us are single issue voters
    jason6541, FreightyAK, Badmon and 4 others Thank this.
  6. Tb0n3
    Tb0n3 Road Train Member
    4,738
    9,651
    Oct 5, 2012
    Earth
    This is just enforcement of environmental regulations. I say about #### time.
    flood, KansasWhirl, PE_T and 3 others Thank this.
  7. Cat sdp
    Cat sdp . .
    21,303
    76,193
    Apr 8, 2012
    Orion's Belt
    Trump’s gonna kill the epa anyways......
    401-Alex, KB3MMX, Bakerman and 5 others Thank this.
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Well, I think that Operation Backfire should be implemented.
    Coop a members private list across the USA on fees. Understand what money is availible. Assemble a leadership, assign members to districts similar to Fed Reserve 7 districts;
    Open shops. That are wholly private and similar to living history operations that preserve whatever that mnight be on the property itself at any given time.
    If the People in the Nation are provided with quality work of any kind on the tractor trailers anywhere eventually with in 10 years or so you will have to make a decison.
    Until trucks are explictly banned under very powerful simple laws written for example Here is a 1959 Ford Shoebox. It does not have seatbelts.
    So the protection provided by the 1963 act of Congress therein saying that ALL cars built on or before 1963 are not to be forced to have seatbelts because is was OPTIONAL back then.
    So that act and all the related acts will have to be struck down, repealed and so on.
    When I worked on one of my cars that was eventually to be sold at auction. As a lemon, good for farm work only. If you want to put it on the interstate? Its your ### at risk in there not me.
    The reason? Maryland would not issue a basic historic tags newer than a certain model year. The Use of Historic tags instantly bypassed ALL inspection, ALL medical lift, ALL emissions ALL and ALL and ALL. Especially the onerious inspection requiring you to restore a vehicle to factory conditions concourse as built.
    Straight to the junk yard. Or hold on to it under your tarp in the back lawn until the Govt dreams up another lemons for junker rebate...
  9. Long FLD
    Long FLD Road Train Member
    12,869
    53,864
    Mar 4, 2015
    I disagree with you on this. It’s not really overreach when a company pretty much bases their business model on skirting federal regulations.
  10. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Doesn't matter, it's my property what I choose to do with or to my property is no buisness of yours or the government unless you can prove it directly hurts you, not could, not might, actually does hurt somebody.
  11. Opus
    132,271
    I agree.
    Why should the rest of us have to follow the rules?
  12. Cat sdp
    Cat sdp . .
    21,303
    76,193
    Apr 8, 2012
    Orion's Belt
    You don’t .......
    D.Tibbitt and nikmirbre Thank this.
  • Thread Status:
