EPA2004 DT570 could not Start
Discussion in 'International Forum' started by owenzhou, Dec 5, 2019.
  1. owenzhou
    owenzhou Bobtail Member
    24
    Feb 10, 2014
    There is a international 7400 with Epa2004 DT570. Engine warning light on the instruments panel. Now the engine could not start. only one active code 543.ECM/IDM communications fault. The ECM fuse in battery is OK.
    If any one have good idea. Thanks in advance.I get a new IDM, If IDM need to be programmed?
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    The IDM has it's own power supply, fuse and relay. Check those too. Very common for pins to get weak and make poor connection and actually cause heat due to the current draw and melt the connector.
  4. owenzhou
    24
    Feb 10, 2014
    Thanks,Heavyd. I got new IDM, It needs to be reprogramed?
  5. owenzhou
    24
    Feb 10, 2014
    After reprogram IDM, the engine could start.
