Hi,
How do you guys like to store your equipment, especially your chains? I’m looking for a neat and tidy way for when I pick up my truck later today.
Best regards, John
Equipment Storage
Discussion in 'Flatbed Trucking Forum' started by farmerjohn64, Jun 24, 2020.
Page 1 of 15
You actually did it? You got out from under that bs trainer and proved yourself? That is awesome! Congratulations man.
Chains were locked on or in the headache rack/cabinet and binders paired with the chains
and extras are locked down too.
If you have padlocks lube every two weeks and take some tennis balls and cut a slit in each and slip over the lock. A small drain hole in the bottom will take care of rainwater.
Ensure you lube regularly as there is no more frustrating time than trying to remove a seized lock on a jobsite after hours when the shipper went home and you can't move until you can tie down the load!
I lube with fluid film and rinse with acetone after 3 months.blairandgretchen, not4hire, Coffey and 4 others Thank this. -
I store mine in my headache rack. 6 chains n binders on each side. If u alternate chain, binder, chain, binder , etc and then hook the end of the chain inside the bottom binder hook , it keeps the hook from spinning out of the binder and falling into the deep depths of headache rack hell ..also keeps the chains from getting tangled
blairandgretchen, singlescrewshaker, Speed_Drums and 8 others Thank this. -
That's how I've seen them on skateboards I've passed. Looks sharp and organized.Coffey, farmerjohn64, G13Tomcat and 1 other person Thank this.
Haha thank you, thank you very much
Congrats, @farmerjohn64 ~!!
Nice organizations, @D.Tibbitt ~!! Very impressive.Kyle G., Coffey, SmallPackage and 4 others Thank this. -
Thanks everybody
U will figure out which way u like to organize stuff for ur workflow. Mine is setup for me and the way i like to work... i go thru the same process every load. Flatbed is all about time efficiencytommymonza, G13Tomcat, Coffey and 2 others Thank this.
Congratulations on being set free.....
Page 1 of 15
