Equipment
Discussion in 'Flatbed Trucking Forum' started by ReeferOhio, Mar 18, 2015.
  1. ReeferOhio
    ReeferOhio Medium Load Member
    596
    557
    Nov 29, 2010
    I know this has been posted and I cannot find it. What equipment do you carry on your flatbeds? I.E. Tarps and sizes, protectors, blankets, straps..... Thanks. Or is someone can link me to the posts I've seen before with these list that be great!
  3. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    12 - 5/16" x 20' chains
    2 - 5/16" x 14' chains
    10 - snap binders
    4 - ratchet binders
    12 - 4" straps with hook ends
    6 - 4" straps with chain ends
    2 - 4" ratchets
    2 - 4" stake pocket winches
    20 - 2" x 30' straps
    20 - 2" ratchets
    12 - heavy duty 24" vee boards
    20 - small red vee boards
    20 - edge protectors
    bunch of old 4" strap pieces for protection
    12 - furniture pads
    winch bar
    6 - coil racks
    6 - 8' 4x4's with chamfer
    6 - 8' dunnage 5x4ish
    2 - 16 x 28 tarps
    1 - 16 x 20 tarp
    1 - 16 x 16 tarp
    1 - nose tarp
    I also have 2 25x24 tarps with flaps I carry sometimes, when going to northwest mostly.
    150 - 21" bungee's.
    OS flags, banners, lights gathering dust.
    That's the main stuff, I have a few odds and ends, short chains with rings, hand tools, usually keep a few short pieces of dunnage, 2x4's some nails, etc... crowbar, snips for cutting banding, fifth wheel puller (comes in handy for pulling chains and strap hooks too)
    JoeBear, MJ1657, raylittlebear and 3 others Thank this.
  4. SheepDog
    SheepDog Road Train Member
    3,482
    2,084
    Nov 30, 2008
    Sand Lake, MI
    Do you have a suggestion on where to get good 4x4's? and is there a particular type of wood to use, or is any hardwood good? I have pine 3x3's now and I want to replace them with 4x4's...Plus I need two 4x6's or 4 4x3's for my leveler's...
  5. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    If you have a sawmill around that would be about the best place.
    SheepDog Thanks this.
  6. SheepDog
    3,482
    2,084
    Nov 30, 2008
    Sand Lake, MI
    Ok,,,thanks for replying so fast. I know where there is one so I will hit them up next time I am home. If beveled, can they still be used for other purposes? I am trying to lighten my trk/trlr 500lbs so, I don't want to carry anything I don't need. I can currently only haul around 37,500 lbs with full tanks.
    MJ1657 Thanks this.
  7. MJ1657
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    I can't see why beveled would be a problem for most anything you would haul. I don't haul coils so my dunnage is not beveled though.
    I'm sure others could chime in if beveled would be an issue for general freight.
  8. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    You can use beveled lumber for general freight like lumber, flat steel, and such. I never had a problem doing it.
  9. SheepDog Thanks this.
  10. SheepDog
    3,482
    2,084
    Nov 30, 2008
    Sand Lake, MI
    After thinking about it, instead of just going off the cuff,,I realized that the only thing you need beveled wood for is coils so, why would you need more than say 6 peices? I can only haul up to 48Klbs so, that is most likely never going to be more than 2 coils, especially since I don't haul them much. So, I figure 4 beveled sticks aught to do it and the rest can be just regular 4x4's..
    MJ1657 Thanks this.
  11. ReeferOhio
    596
    557
    Nov 29, 2010
    The most I've hauled legal is four coils that had to be suicide one after another. But that was before I only hauled steel, and I ran them on straight 4x4's. I see most with three or less, with three coils you could almost have two sets of 4' dunnage and one 6' set and be good. That's how i'd do it if I where over the road open deck.
