Erratic cruise/speedo problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gokiddogo, Feb 5, 2014.
  1. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Truck is a 2000 Freightliner Classic. It is equipped with a bullydog hdgt so I can see what the ECM is broadcasting. Maximum cruise set speed is 62 mph.
    The problem: speed up to max speed, set cruise, it thinks the truck is slowing down and then hammers the fuel until you are about 68-70, then realizes its going too fast, then cuts out. Repeats. The ecm shows the correct speed until power is applied to more than about 50% engine load, the ECM (and speedo) shows that you are slowing down into the 50s, then hammers. If I cruise with my foot, and keep engine load low, the speedo and ecm read closer to what actual speed is. If I let it coast, both ecm and speedo read perfectly.
    When I bought this truck, the speedo was seized, that was April 2013. New speedo installed then, has been working perfectly. Appears to be reading the distance correctly for where the ecm tells it to point. Mechanic has looked over this and has replaced trans speed sensor and adjusted the air gap. I have also recently had the alternator replaced, not sure if this makes a difference, as the engine works harder it seems to read more off - could it be there is some kind of bad ground somewhere?
    Any ideas ?
  3. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    Check the output shaft on the tranny loose yoke nut will do that
    gokiddogo Thanks this.
  4. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Well. speedo problem is still here. Yoke nut is tight. Had new speedo head put on when I bought this truck April 2013, it has 172,000 km on it so far. New speed sensor on the transmission and adjusted twice for the spacer (by mechanic) ... when in 18th gear, speedo shows exact speed truck is moving IF no throttle is pressed. Apply throttle to maintain speed and it dips below actual speed (never shows faster) erratically by a few mph ... which throws the cruise off so I haven't been using cruise at all. Cruise works fine if I want to just put on high idle while not moving. However, if I am driving and need to go down to 17th and then mash the throttle, speedo shows about 50% of actual speed .. again, let up on throttle, shows correct speed ... I believe it is also reading the distance traveled less than actual distance moved now also. Today google says I should have drove 964 km, speedo shows 888 ...
    I don't even know where else to look at this point ...
  5. jameslawton
    257
    65
    May 1, 2013
    Tulsa OK
    Pull the yoke off and check to make sure the tone wheel is getting pressed tight and check to make sure tail shaft not loose bearings also check wires going to ecm they do rub where they go over the bell housing and can make Speedo bouce if they short out
  6. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Thing is - it reads the speed exactly what it is if there is no throttle applied. All the way down to zero if I coast it down. ??
  7. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    You didn't mention what engine you have. I suspect you have throttle pedal and speedo wiring possibly rubbing through on each other scrambling the signals. The only place I can see this happening is near the ECM where the OEM harness plugs into it. Make sure nothing else is interfering with the electronics. Unplug your Bullydog and anything else such as a satellite and retest. If the problem is still there you should be checking into the harness for problems. Bad or dirty grounds can cause issues like this too.
  8. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Question on that Heavyd,
    Any idea on what would cause the speedo to dip much more while the splitter is pushed backward, as in 17th, it seems the more fuel you give it the more it dips, however in 18th with splitter forward, it is only slightly erratic? Same thing happens in 16/15 all the way down, just more noticeable in the bigger gear because of higher speed
    Detroit 12.7, ddec4, engine is a 99
  9. Heavyd
    7,804
    6,253
    Feb 4, 2009
    You have a very intriguing problem that I would love to dive into. I cannot see how the mechanical operation of the splitter would effect that if everything is good at the tail shaft. There is probably something specific with your truck that I am not aware of. I would say it has to more with RPM range the engine is at during those gear selections.
  10. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    I know this is a bit old, but I just ran into the same type issue. 2000 Pete with a 12.7 S60, 13 speed. Erratic speedo that was worse/better with the splitter. This has the screw in VSS and it came loose making the air gap too large. The only thing I can guess is that maybe the splitter one way gives a little less tail shaft movement? Still confusing, but I adjusted the air gap and the problem is gone.
    Oh, and the driver said that it always read right when coasting. This is just another guess, but the pressure on the gears coasting must hold some slop out the the tail shaft to get a good reading.
    Maybe your mechanic adjusted the air gap too large? Or it's possible that you have some bearings going in the back of the trans making too much play in the tail shaft?
    Heavyd Thanks this.
  11. Heavyd
    7,804
    6,253
    Feb 4, 2009
    Yes, I think you are right, different amount of torque applied resulting in different shaft loading.
