Espar bunk heater question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Lee Thompson, Oct 9, 2018.
  1. Lee Thompson
    Lee Thompson Bobtail Member
    10
    6
    Sep 28, 2018
    I previously posted about my bunk heater problem. But the video that was suggested, doesn’t address my problem. My heater works, to well, I start it and regardless of where I set the temperature, it just keeps getting hotter, till I have to shut it off. I need help with, is it the digi controller that is bad, or the ecm module, in the heater itself?
  3. driverdriver
    driverdriver Road Train Member
    4,254
    5,283
    May 30, 2011
    So are you saying it keeps blowing full blast even after reaching set temperature.?
    Mine continues to blow but at a significantly reduced flow of air.
    Sometimes I just have to shut it off.
    Sometimes I crack both windows.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    What style of controller / thermostat do you have?
    Lee Thompson Thanks this.
  5. Lee Thompson
    10
    6
    Sep 28, 2018
  6. Lee Thompson
    10
    6
    Sep 28, 2018
    Yea it blows full blast till it gets to hot for me and I shut it off
  7. brysol01
    brysol01 Medium Load Member
    312
    445
    Nov 2, 2009
    just bought a truck with one, seemed to work good but quit, are you suppose to have it on with the truck running?
  8. Lee Thompson
    10
    6
    Sep 28, 2018
    Mine is set up to shut off when the trucks running, or the key is in the run pos
  9. driverdriver
    4,254
    5,283
    May 30, 2011
    No.
    And when you turn it off you need to let burn off before you start your truck.
    Takes 3 to 5 minutes , put your hand by the vent when it completely stops blowing you can start your truck.
    sealevel Thanks this.
  10. driverdriver
    4,254
    5,283
    May 30, 2011
    Sounds like you need to get it serviced.
  11. Luwi67
    Luwi67 Heavy Load Member
    749
    484
    Oct 24, 2012
    Long island
    Your thermostat or sensor is in a position where it is too cold and gets no heat. Try moving it closer to where you usually are and see what happens.
    uncleal13 Thanks this.
