Espar Engine Heater Questions
Discussion in 'Trucks [ Eighteen Wheelers ]' started by billandlori, Dec 14, 2014.
  1. billandlori
    billandlori Medium Load Member
    357
    106
    Sep 5, 2010
    Stratford, Ontario, Canada
    I purchased an Espar Hydronic SC with the Espar Easystart Timer.
    You'd think two different companies made them lol. I have the unit all installed but ran into some wire color confusion between the timer and the heater. I don't want to toast anything so I haven't finished up the timer connections.
    I have four wires coming from the heater going to the timer:
    Red/Yellow
    Yellow
    Brown
    Blue/White
    The Instructions from the heater say the wire colors should be:
    Red - "+" Batt power
    Yellow - Switch control to heater
    Brown - "-" Batt
    Blue - Diagnostic from heater
    All wires go directly to the timer.
    There are 10 wires on the timer, the instructions say to hook them up as follows:
    Red - to heater
    Brown - to heater
    Blue/White - to heater
    Grey/Black - to IGNITION
    None of the other wires are to be hooked to anything.
    Simple eh??
    I can figure the + and - for batt power but the other two wires are a bit of a mystery!!
    If anyone else has run into this, how did you hook them up??
    Thanks for the help
    Bill
  3. billandlori
    357
    106
    Sep 5, 2010
    I guess not many folks run the Espar heaters. I'll give the manufacture a call.
    Bill
  4. billandlori
    357
    106
    Sep 5, 2010
