Espar power drain
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by tnc110, Dec 5, 2022.
  1. tnc110
    tnc110 Light Load Member
    135
    81
    May 22, 2016
    Just curious as to if anyone else is running into what I’m running into. I have 3 brand new batteries. On cold nights they don’t make it through the night without the low voltage alarm going off, which comes on at 11.6 volts. This is in a flat top Pete with the curtain pulled shut so it’s not a big area. Power draw for d2 claims to be:
    8.3 amps - Start
    2.8 amps - Boost
    1.9 amps - High
    1.0 amps - Medium
    0.7 amps - Low
  3. DUNE-T
    DUNE-T Road Train Member
    7,043
    17,155
    May 10, 2015
    Detroit, MI
    Why do u think it's Espar and not something else?
  4. tnc110
    135
    81
    May 22, 2016
    good point. I do have a fridge that pulls 5 amp on occasion , but it’s only .35 kWh/24hr. 2022 389 with a cat…not sure what all runs in the background that I’m not aware of. Phone charger. Everything else gets turned off.
  5. dunchues
    dunchues Medium Load Member
    555
    960
    Mar 23, 2012
    new brunswick
    There's a setting on the control panel that sets the heaters low voltage shut off level, yours is prob on 12.5 or something. With mine I use a paper clip in the tiny hole on the front which brings up change settings on the screen, then change to suit.
  6. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    You got a 2022...389.. with a Cat ???
    Gota be glider ??
