Espar thermostat? Input appreciated
Discussion in 'Experienced Truckers' Advice' started by Cascadia2013, Sep 6, 2021.
  1. Cascadia2013
    Cascadia2013 Bobtail Member
    4
    Sep 6, 2021
    Just found this in the bunk of my 2013 cascadia. I'm a fairly new driver (3 years) & I've had an apu before so I know it's not that. I bought the truck last year & I just noticed this little thermostat near the bed. Could be a bunk heater? Any input would be greatly appreciated. I wanna know how to use it or how to check if it's even installed correctly. Thanks!
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Yes,bunk heater.
    Left button is fan only. Right button is turn heat on.
    left bottom is lower set point, right is raise set point.
  4. Cascadia2013
    4
    Sep 6, 2021
    Thanks! I'll try it out when I can. I believe it has the heater under the bed. I really appreciate it!
  5. Brandt
    Brandt Road Train Member
    4,628
    6,362
    Sep 17, 2012
    Test it before you need it. They build up carbon or something and won't start. They blow lots of white smoke out exhaust pipe when that happens. They sell kits to replace the burner and some people just buy new unit and replace the whole thing. They blow out lots of heat when working correctly.
    Dockbumper Thanks this.
  6. sbaumann14
    sbaumann14 Road Train Member
    1,238
    1,434
    Sep 1, 2010
    Rhinelander, WI
    At the end of every year, I burn a half gallon of kerosene thru it to clean it out. Same unit for 8 years now
    msh Thanks this.
  7. WesternPlains
    6,369
    57,406
    Sep 1, 2017
    Rapid City, SD
    They say to run it once a month during summer.
    Biggest thing I’ve found is dust over the intake. Then it won’t work good.
    Keep it clean. Check the filter in it.
    tscottme Thanks this.
  8. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Make sure the output side is free of any (combustible) obstructions. You're getting pure heat out of that thing without any ductwork.
  9. Lucky12
    Lucky12 Medium Load Member
    600
    2,297
    Nov 24, 2019
    I learned here at TTR that when it's not working well, like the flame is going out, etc. is to keep trying and once it gets lit to turn it on the highest heat setting and let it run for an hour or so, like turn it all the way up and then go shower. It does wonders to burn off a lot of the buildup that is preventing it from working well. It is like giving the thing a tune up. Seems like it's necessary every 4-6 weeks to keep it running good.
  10. WesternPlains
    6,369
    57,406
    Sep 1, 2017
    Rapid City, SD
    He'll learn that the first time he leaves his foot in front of the output. :angryfire: :laughing-guffaw:
    msh, HoneyBadger67 and BigBob410 Thank this.
  11. Moosetek13
    Moosetek13 Road Train Member
    14,987
    19,045
    Nov 1, 2010
    Burnsville, MN
    There is a thing that comes with most trucks.
    It is called a User Manual.
    In that strange little thing that you must open, and actually read, are instructions for using all the little things installed in the truck.
    BigBob410 Thanks this.
