Excessive Black Smoke HELP
Discussion in 'Experienced Truckers' Advice' started by 379LNPete, Jun 10, 2021.
  1. 379LNPete
    379LNPete Bobtail Member
    4
    Jun 10, 2021
    I have a 2005 T600 Kenworth with a C15 CAT. I recently rebuilt the motor but did not replace injectors or head. All seemed fine. The truck ran fine for a week after the rebuild and then it started black smoking. I put a few gallons of fuel conditioner in the tanks and changed filters. The smoke cleared up. The truck sat and idled overnight and then black smoked excessively on throttle the next day. When I say excessive I mean black soot anything and everything around the truck. When the truck got back to the yard it just black smoked/soot on the ground excessively at idle. Ive done injector cut out test all checked out fine. Truck isn’t throwing any codes. Truck cranks right up no slow start. Fuel pressure is running around 70 on gauge while going down the road. (That seems low to me) I’m at a loss as to what it could be. Turbo has been checked out and is fine. I’m not sure what else to check/try.
    Fuel lines aren’t stopped up. Any ideas would be greatly appreciated!!!! I have a 3406e CAT in my personal truck so not tons of experience with the Acert. I have several friends that have CAT motors and we’re all out of ideas.
  3. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Any of the boots around turbo piping/charge air cooler. Are you losing any boost?
    slow.rider Thanks this.
  4. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Sounds like turbo even though it checks out.
    Mine wasn't spinning fast enough when I had the same smoke problem. 2005 w900 isx.
    slow.rider and Diesel Dave Thank this.
  5. Diesel Dave
    9,706
    33,119
    Jan 20, 2010
    Hesperia, Ca.
    That was my thinking from the beginning but the op said it was checked already.
  6. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    Might recheck injector adjustment, if set wrong they can cause excessive black smoke.
    Is there a restrictor gauge or boost gauge to see if turbos are getting enough air?
    If it's an acert make sure an iva isnt hanging open, there maybe be a code in ecm, or when you pull valve cover you can see plunger hanging down and it wont return easy prying it up.
  7. drivinhome
    drivinhome Light Load Member
    91
    102
    Sep 16, 2009
    Southeastern Mass
    Black smoke = fuel. Too much fuel and not enough air. From what you have posted so far I would take a close look at the air filter and all intake system.
    Artax Thanks this.
  8. snowwy
    20,612
    13,333
    Jul 6, 2009
    My money is still on the turbo.
  9. okiedokie
    okiedokie Road Train Member
    13,929
    110,473
    Jun 13, 2011
    PNWET
    Back in the day:rolleyes:
    Black smoke was big power.:D
    God prefers Diesels Thanks this.
