excessive coolant usage
Discussion in 'Trucks [ Eighteen Wheelers ]' started by noguns3, Mar 5, 2012.
  1. noguns3
    noguns3 Light Load Member
    52
    13
    Jan 7, 2007
    Minnetonka, MN
    12.7 Detriot Series 60. Adding about a half gallon of coolant every 5000-7000 miles. Runs great, no visible leaks from hoses, 6.7 mpg average. Should I be looking for something, or is this normal on a 1.3 million mile engine?
  3. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Its not normal on an engine of any age. The cooling system is a closed loop - you shouldn't be adding anything to it at all. If its getting into the engine oil, you have a major problem that needs to be taken care of at once. An engine oil analysis would tell you the story for $40 or so.
  4. flood
    flood Road Train Member
    4,169
    4,051
    Dec 25, 2010
    could be the egr cooler, oil analysis at the ta/petro is around $20
  5. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    The very first thing you do is get the rad cap tested, and if you buy a new one get it tested. Stant is having a problem. Freightliner sells a good cap.
    Places that leak small amounts, I would be looking at the sleeper and cab heater connections, and the drains for the heaters.
    Look for the cheap stuff, first!
  6. gerardo1961
    gerardo1961 Road Train Member
    1,754
    624
    Feb 21, 2010
    Miami
    before i have the same problem with coolant,after changing headgasket,everythink was normal
  7. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    I would be looking at the water pump first if it doesnt leak from the waterpump itself then its going right in the oil.
  8. Ruthless
    Ruthless Road Train Member
    9,223
    91,689
    Aug 28, 2010
    The City.
    Me too. Do look at the cheap stuff, but do an oil sample! Is it pumping out the top thru the cap? Either the cap is junk, or you're adding ore compression to the system (compression from the cylinder is coming out throught the coolant system/new head gasket)
  9. ladywrongway03
    ladywrongway03 Heavy Load Member
    766
    329
    Aug 28, 2008
    trotwood oh
    Just purchased a 2007 and was losing coolant.The seal on the top of radiator was oozing coolant.Replaced radiator with metal after market and no problem
  10. Bigd41302
    Bigd41302 Bobtail Member
    4
    Sounds like you possibly could have counterbore issues. Have seen this a lot with high mileage 60's. If all the obvious checks have been done, rad. Cap, EGR cooler, air compressor,etc... Pull the exhaust pipe off the turbo and check turbo outlet for signs of coolant, white streaks. If there is then cylinder head needs to pulled. If you find the head gasket to be leaking. 9 times out of 10 it was due to liner protrusion issues, ie..counterbores. Also there is a certain reman cast of the EGR cylinder head that is known crack.
