Excessive water getting into belly dump air lines
Discussion in 'Experienced Truckers' Advice' started by shaff1965, Jan 15, 2024.
  1. shaff1965
    shaff1965 Bobtail Member
    28
    Aug 21, 2017
    san angelo tx
    Hi everyone!!
    Been having a water build up issue in my air lines. All is fine till it gets colder Temps. Then the water freezes and air cannot go through lines.
    It's a belly dump trailer
    My truck is a 2000 freightliner
    Question: could it be a compressor issue or air dryer issue? Or both?
    The air dryer purges about every 10 seconds or less.
    Not normal, I know...
    I cannot figure out why so much moisture is getting into my air lines!!
    Please help.
    PS I don't want to know how to remove the water. I need help/advice on how to prevent it from getting in.
    Thank you!!
  3. 062
    062 Road Train Member
    6,337
    33,982
    Oct 20, 2013
    Fix air leak causing compressor to run all the time.
    Drain tanks.
    Change drier cartridge.
    @JB7 @Goodysnap may be able to give better information.
    Busy day.
    JB7, JoeyJunk, Rideandrepair and 5 others Thank this.
  4. Banker
    Banker Road Train Member
    4,534
    14,759
    Aug 19, 2012
    Have you changed the filter lately?
    JB7, JoeyJunk and Rideandrepair Thank this.
  5. pavrom
    pavrom Road Train Member
    3,217
    7,422
    Apr 29, 2012
    NE illinois
    try draining water..
  6. Rideandrepair
    17,572
    56,926
    Aug 8, 2015
    X2 Drain the tanks. Excessive air dryer popping off is a sure sign they need draining. If it continues afterwards, you probably need a new dessicant filter. Probably have an AD9 drier. They’re cheap, Might want to change the whole thing.
    JoeyJunk Thanks this.
  7. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,957
    Oct 31, 2023
    Drain your tanks more often. The condensation builds up and fills them with water. Not that big of a deal during the Summer but once it dips below freezing it'll make your life miserable. Also, add some deicer or alcohol in a punch.
  8. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    fix the reason your dryer pops every 10.seconds. that will help
    062 and JoeyJunk Thank this.
  9. Ridgeline
    22,744
    123,726
    OMG replace your air dryer cartridge, this is why.
