When the air compressor is building air and the engine has warmed up, there is a noisy racket coming from the exhaust back flow valve area. When the air compressor cuts off, the noise is gone. Air pressure then falls from 135 to 118 psi in about 2 mins. Searched for air leak. Dealer says air compressor is good, should be, it’s new OEM. Replaced Air Control Valve (OEM) recently due to an air leak from its body. Sure hope this sounds familiar to someone!
Exhaust Back Flow valve issue 2013 Maxxforce 11
Discussion in 'International Forum' started by joejffrs, Nov 27, 2018.
