External SWR meter, switch in S/RF or SWR position?
Discussion in 'CB Radio Forum' started by Agtrucker, Sep 25, 2016.
  1. Agtrucker
    Agtrucker Light Load Member
    159
    47
    Dec 14, 2011
    I recently picked up a astatic meter to set up my swr/troubleshoot a cobra 29ltd. Maybe this is an dumb question, but when the meter is hooked up and I'm testing do I want the selector switch on the radio to be in the S/RF position or in SWR position? Thanks..
  3. wolverine11
    wolverine11 Road Train Member
    1,628
    1,234
    Apr 1, 2015
    S/RF, SWR position would be if you are using the built in meter to check the SWR.
    Agtrucker Thanks this.
  4. Ridgeline
    22,746
    123,786
  5. Agtrucker
    159
    47
    Dec 14, 2011
    Thanks guys... I knew if using the built in meter I'd use the SWR switch but then I wondered if it somehow had an effect while using an outside meter to..
  6. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    If you wanna compare meter then leave it on s/rf
