F350 and cargo trailer on a step...
Discussion in 'Flatbed Trucking Forum' started by DieselDog81, Jun 29, 2014.
  1. DieselDog81
    DieselDog81 Medium Load Member
    415
    213
    Apr 7, 2012
    Between here and there
    If your loading a F350 and a cargo trailer on a step, can you leave them hitched together while in transit? Or do/should the be seperated?
  3. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    I'd separate them. The trailer is meant to move when it's hitched, and that isn't what I'd want it to do.
  4. dirtyrabbit
    dirtyrabbit Medium Load Member
    416
    158
    Jun 19, 2011
    KS
    I've seen them hitched together, but it would make sense to separate them.
  5. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    guess this is opinion. I'd leave them hitched. I hauled a couple military items hitched, figured securement on one helps secure the other that way. plenty of securement on both anyways, guess it doesn't matter.
  6. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Put the jack leg down but leave them hichted. What i would do
    lester Thanks this.
  7. DieselDog81
    415
    213
    Apr 7, 2012
    Heres what I was thinking... if I left them hitched, the truck would be moving and bouncing slightly since id secure it from the axles so that the chains dont jerk and bounce with the suspension, and the trailer which doesnt have any suspension other than the tires would be secured from its frame... so itd be limiting the rear of the truck to move which in turn would cause slack in the securement...
  8. Gordon A
    Gordon A Medium Load Member
    384
    345
    Jul 22, 2013
    Dont put the jack all the way down. Some rough spots on road and the flexing of trailer could cause the up down movement to drive the jack foot into the floor. With a load on and a hole in the floor is a no no and damage to jack.. To be sure load doesn't move and no damage to wires and other stuff. Put a 2" in strap across the top inside of a tire and then pull down to the closet stake pocket either side of wheel. Do both units . Steer, and drives on pulling unit & Trailer . PLUS your chains.
  9. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I've pulled several P/U, stake body and assorted other trucks with trailers. Horse trailer, cargo etc.
    I found the simplest method was to just use wheel straps on both the trailer and the truck. Larger trucks F600 or larger I would use chains. The wheels straps I have are rated 5400lbs working limit each. 5400 x 6 = 32400. More then adequate for a 1 ton tuck and small to medium sized trailer. I just let em bounce back there. They arent going any where provided the hitch is locked and safety chains are securely attached.
    I have done them separately before I got the wheel straps. The wheel straps save so much time.
    I recently hauled 2 F550 extended cab trucks equipped as small fire trucks. I used the wheel straps on both units and placed a single safety chain and single binder on each for just in case. No issues what so ever from Pomeroy Wa to Baltimore Md.
    Hurst
    DieselDog81 Thanks this.
  10. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    I have no experience in trucking, but what I see is the potential for damage to the trailer tongue, and or tongue jack if this method is employed. The suspension on the F350 is going to be active while being towed, with the tongue jack down it will act as a fulcrum between the truck and the remainder of the trailer. A few good bumps in the road and the rebounding of the F350 suspension and that trailer tongue is likely to get bent by the force, whether all at once or as a cumulative effect.
    I would not choose to lower the tongue jack, I see no reason. The hitch and coupler are meant to articulate, leaving it active as if the truck and trailer are moving down the road allows the suspension on both parts to work as they should.
    FWIW
  11. DieselDog81
    415
    213
    Apr 7, 2012
    I totally agree with you. And id use wheel straps if I had them. But I currently dont have any and I doubt that im going to be able to find six between now and then... So in lieu of them, could I use 2in straps wrapped around back of the wheel and crossed in front instead?
    I definitely think that im going to leave them hooked together, and with out putting the jack down. As Alaska76 stated they are meant to articulate and pivot off the ball and having the jack down with either cause damage to the cargo trailer or to the deck of the stepdeck trailer
