Factory shore power plug
Discussion in 'Peterbilt Forum' started by brianw900, Dec 8, 2014.
  1. brianw900
    brianw900 Bobtail Member
    49
    15
    May 16, 2011
    Has any bought a new 579 or 389 with the factory shore power and had the male end on the truck have one prong verticals and the horizontal. Just trying see if this is a mistake or if they are really like that, called a couple of dealers and haven't gotten a straight answer.
  3. Scott101
    Scott101 Medium Load Member
    607
    407
    Nov 30, 2008
    NorCal
    Sounds like a 20 amp plug.
    Ideally you would only plug that into a 20 amp receptacle/extension cord. But there are adapters that would allow you to plug into a standard 15 amp receptacle/extension cord.
  4. Scott101
    607
    407
    Nov 30, 2008
    NorCal
    Here is the difference between a 20 and 15 amp receptacle:
    Does it look like it would plug into one of these?
  5. brianw900
    49
    15
    May 16, 2011
    Yes but the other issue that the horizontal prong would be on the opposite side on the truck, it truly is an oddball. Checked a few recreational places but the all have the adaptor sand cords designed for what your pic shows. Thanks for your input on this.
  6. Scott101
    607
    407
    Nov 30, 2008
    NorCal
    Oh, Is there a NEMA designation on the plug anywhere? Like 6-20P, or 250V-20?
    Does it look like any of these?:
  7. brianw900
    49
    15
    May 16, 2011
    6-20P is what it is. Thanks again for your help .
  8. Scott101
    607
    407
    Nov 30, 2008
    NorCal
    Cool. You're welcome.
    I don't know a whole lot about shore power setups. But that 240v circuits seems weird to me. --2 Hots, Ground, No Neutral!
    I'm curious how they are doing that. I would think a 30Amp 120volt circuit like they do on small RV's would make more sense. I've also seen big 50Amp 240volt RV circuits, but those are 4 wire. --They give you a neutral!
    Oh well, I'm sure those engineers know better then I do...
  9. DeGuzzie
    DeGuzzie Bobtail Member
    22
    14
    Mar 30, 2015
    Benson, Vermont
    I just want to say thanks to everyone who participated in this thread. I just recently had battery issues and the terminal I'm at has receptacles for trucks with 6-20P to a 6-20R.
    KB3MMX Thanks this.
  10. Dowhat555
    Dowhat555 Bobtail Member
