Fan clutch don't come on
Discussion in 'Freightliner Forum' started by Trayn8387, Feb 10, 2015.
  1. Trayn8387
    Trayn8387 Bobtail Member
    26
    Jan 21, 2013
    I have a freightliner century class my fan don't wanna come on I changed the fan clutch, selioid, and thermostats don't know what else to look for any help would be nice thanks
  3. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    Did u what happens when u turn ignition off so u hear the solenoid release the air or can u spin fan with ignition off
  4. Trayn8387
    26
    Jan 21, 2013
    Yes when u turn the truck off and just turn the key on u can spin the fan but with key off u can't turn it
  5. nasriza
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    What temp does you're truck get up to fan is supposed to kick on at 210f also u can try to turn on with ac system of fully charged when high side pressure gets to 300 psi fan will come on there is nothing really that keep the fan off If its working with ignition that means that all the wiring is good because you're solenoid gets 12 v to shut off fan not turn on when it's on there is no power at solenoid
  6. marineman227
    marineman227 Dock Waterer
    600
    796
    Jan 26, 2008
    Neenah, WI
    Not sure if it's the same on freightliner but on my old Volvo there was 1 plug that I could unplug and it would lock the fan on. If you can find it and do that it will tell you at least which side of the system the problem is. If it works somehow it's not getting the electrical signal it needs. If that doesn't work it's not getting the air to operate it. Unfortunately for me when my fan went it was the clutch itself so I couldn't even lock it on. Had to have a mechanic come and shim it so I could drive home and get it fixed.
  7. Trayn8387
    26
    Jan 21, 2013
    Oh ok well I ll change the ac high pressure switch and see if that works but someone told me that the water temp sensor could be bad or the wire going to the computer is broke or rubbing don't know if that's true or not
  8. 062
    062 Road Train Member
    6,364
    34,088
    Oct 20, 2013
    What is your voltage at solenoid?
  9. Trayn8387
    26
    Jan 21, 2013
    Idk didn't check it
  10. Puddinhead
    Puddinhead Bobtail Member
    4
    Jul 27, 2018
    If that true for the 2004 FL M2 106, no 12v to solenoid when fan is running, only 12v to solenoid when fan should stop running? My '04 FL M2 106 freely spins with engine on or off, and fan only comes on when over 210f, I want fan ON much earlier so I'm not kissing 210f all day in Florida heat. Even with A/C ON my truck kisses 210f all freaking day ! That's too hot for the Alllsion 3000 which intermittenlty stops downshift when engune at 210f.
  11. nasriza
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    Well i don't know exact fan control on M2 if this is solenoid controlled or not, if it is find solenoid and you can wire a switch inline to force the fan to stay on when you want it on, that being said the more that fan runs the worse fuel economy you are going to get. hope this helps.
